Quote Originally Posted by paolorenzo View Post
Ayoko na talaga sa Amaron. My 3smf installed on 9/4/2015 is again dead. Nag lobo na sides. To think this was a replacement unit. And weekly top up with Ctek battery charger.
Panasonic naman.
I'm also using CTEK battery charger, but not for Amaron. I'm using it for the factory issued battery. Perhaps I'll update this CTEK two years from now.
Quote Originally Posted by SpinCycle View Post
That test worked back when cars didn’t have too many electronics. If you pull out the terminal with the engine running, you’re letting your electronics to receive max volts which can end up frying them if they can’t handle it.
Best test is to use a voltmeter. Voltage should read between 13.8 to 15.3 with the engine running and nothing else turned on.
That answers my question, thanks.
