Results 1 to 20 of 2297
Threaded View
    Jan 2009
    mga ka-tsikot ask ko lang. 2015 fortuner MT 2kd-ftv. stock wala naman ako accessories na power hungry like a killer sound system.
    worth it ba mag 3sm pa na battery or balik 2sm uli from the factory? amaron pa din. libo din kasi price difference. salamat
    If the stock battery is 2SM, you'll be fine with a replacement 2SM. Practical advantage lang ng 3SM is the bigger reserve capacity and cranking Amps. Depending on actual use, the additional capacity may offer some insurance in starting the engine even if an accessory was left on overnight, for example, or if you run into an engine issue that requires you to crank it longer than usual.
    It's up to you if you feel that the extra capacity is worth its weight (literally) in Pesos.
    FWIW, I have a 3SM Amaron in my 2.5 Innova G.
Amaron battery
