Page 93 of 115 FirstFirst ... 4383899091929394959697103 ... LastLast
Results 1,841 to 1,860 of 2297
    #1841
    Quote Originally Posted by GTi View Post
    Yes, I have tried their SF Sonic once. They said it was just as good as Amaron but cheaper. I was disappointed. Mine lasted only a few days after warranty expired. [emoji28]
    Sent from my SM-G965N using Tapatalk
    i am amazed at the batteries' timing of demise.
    they probably hire high-powered scientists, to accomplish this.
    #1842
    Batteries use chemical reaction to produce voltage. You can compute for the rate of decay of the materials inside the battery.
    Apr 2008
    #1843
    Seriously! If I had come over a few days earlier I would have saved me over 5k. [emoji38]
    The first Amaron I bought lasted over 3 years. From the anecdotes here in Tsikot, that is actually a rather short life. Though that battery was discharged a number of times since the Granvia it was installed on had alternator trouble. All the other Amarons I bought after, at least among the cars that are still around, are still functioning well.
    But the Santa Fe the SF Sonic was installed on never had any electrical trouble!
    #1844
    we have to take into account, the type of traffic the car does.
    highway is the battery's friend.
    city stop-and-go, especially night time, is the battery's fiend.
    my son got over 4 years from his battery. he drove highway.
    i got 13 months, or a month after warranty expired. i drive city, half being at night. i also used to turn off my engine at long stoplights.
    same car model, same battery. (champion, by motolite. it was cheap, back then.)
    Apr 2012
    #1845
    Seems like Hyundais have a good charging.
    Even on my Grand Starex, tumagal ng almost 5 years yung Amaron.
    Sa Toyotas ko ngayon ko pa lang masubukan.
    But in my vios it's 2 years already. Never had trouble pa.
    Unlike sa Motolite sakto after warranty sira na
    Sent from my SM-A507FN using Tapatalk
    Jan 2009
    #1846
    Not categorically. It's case-to-case.
    We had four Hyundais in the past (not all at the same time)... 2 Getz and 2 Starex.
    One of each type of vehicle has had their alternators replaced due to non-charging.
    And get this, the charging fault idiot lamp never lit up in both cases. The driver didn't have a clue that the vehicle was just running off of the batteries until the engine failed to start.
    pretty good experience on my elantra too.
    Jul 2012
    #1848
    my amaron battery on vios starting to have white powders on terminals, bought january 2016
    #1849
    Quote Originally Posted by enzo6k View Post
    clean it, and see if it re-occurs.
    Feb 2019
    #1850
    The old battery that we trade-in to Amaron shop what will they do with the old battery? Sell it to junkshop or recycle it?
    #1851
    the lead is recycled.
    the old hard rubber casings were re-cycle-able, also.
    i do not know if today's casings are re-cycle-able. i think it is. it seems to be some sort of thermoplastic...
    Jul 2012
    #1852
    thanks doc, will clean it tomorrow. what to do if still occurs?
    #1853
    if it is out of warranty, i'd open the filler holes and see if it needs water. the plates should be completely submerged, kasi.
    Jul 2012
    #1854
    ok i see, hoping it will still last a little more. thank you
    Feb 2018
    #1855
    I find that Amarons in Jawe are cheaper than elsewhere. Have been buying from them for about 10 years now and am quite satisfied with their service. Their drawback indeed is that they do not have home service and are closed on Sundays. Though that is negated since we have more than one vehicle, so jumpstarting is thankfully always an option.
    magkano kaya sa kanila? say for a ns60l hilife?
    May 2017
    #1856
    Motolite owns the maker of Yokohama batteries in Malaysia pala ha!
    #1857
    If only Ramcar/Motolite would deem Ph deserving of their world-class batts, Exide & Marshall, there'd be no competition....But nope, those aren't warranty-timer equipped.[emoji13]
    We're not worthy!🤪
    Feb 2019
    #1858
    I recently bought a car charger that have voltage reading. I have a car that I rarely use so if I plug in the car charger and it registers 12.5V that means battery is good? and when it becomes less than 12V when I plug it in that means I have to start the car so that battery can recharge?
    Jan 2008
    #1859
    Why start the car when you have that car charger? You plug it to charge the battery..
    12V reading is not guarantee that the battery is good.. while it is holding 12V charge.. it should be able to at least maintain that with load
    Feb 2019
    #1860
    No I mean the cellphone charger that you plug into lighter socket it comes with voltage reading sorry for the confusion.
Amaron battery
