Page 90 of 115 FirstFirst ... 4080868788899091929394100 ... LastLast
Results 1,781 to 1,800 of 2297
    Feb 2019
    #1781
    since pupunta ka ng banawe
    meron panasonic battery dealer diyan sa banawe near retiro
    di ko alam kung nandun pa
    kinuha ko sa google map ang photo
    di kasi tumatagal mga tenant sa building na yan
    Okay thanks! will visit them tomorrow and decide which to get.
    #1782
    Yung Ice Monster naalala ko diyan Uls
    #1783
    That shop is owned by TPL din. You can canvass there also.
    Okay so just same seller different names. Are you a long time Panasonic user how long did it last? based on your price it is a bit less compared to Amaron Hi-Life also 21months warranty.
    A little over 2 years palang longest Panasonic ko. Thats the JP blue series installed in our innova. The rest are quite new pa, 6 months palang or less. Can't comment on their longevity pa.
    yeah
    there's something wrong with that building talaga
    walang tumatagal diyan
    #1785
    yeah
    merong ganyan.
    "isinumpa!"
    except the jollibee and macdonald's outlets.
    kahit na napakasama ang location, hindi aalis yung isa, habang nandiyan pa yung kabila.
    "to do so, would be to admit defeat."
    Feb 2019
    #1786
    Okay noted on this. Thanks!
    Feb 2019
    #1787
    merong ganyan.
    "isinumpa!"
    I will also see tomorrow if restaurants are still open or many are already closed I live nearby the area but im at work on weekdays so I can only check during weekends.
    #1788
    As far as I know, yung DIN sizes ng Amaron is just the Pro model, no Go or HiLife model. I have used Amaron Pro DIN66 on the old Fiesta Ecoboost and Amaron Pro DIN60 on the Jetta TDI.
    thanks bro. naintindihan ko na. basta DIN itim. nag base ako kasi sa kulay..ang high life at go green. tapos yun pro itim kaso meron pa palang hi-life na pro pero green din ang kulay.
    Feb 2019
    #1789
    What might have cause the battery to explode?
    May 2017
    #1790
    Could be a defective alternator overcharging the battery by over 15 volts
    Jan 2009
    #1791
    ^ Ouch! Looks like hydrogen gas build-up and something ignited it.
    My Amaron 115D31L 21-month warranty is about to end next month. So far, it's still at 100% SoH.
    On average, my car was only being used about 2-3x a month from the time the lockdown started. I guess the smart charger was really a worthwhile investment. Prior to plugging in the charger, the battery SoH and SoC were at 98% and 68%, respectively.
    #1792
    You leave your batteries charged until you need to use the car? Or unplug it once done charging?
    #1793
    Belated happy birthday CB!
    This is worrying. Not the first time I've heard of Amarons exploding. Getting a little scared of the one in our CR-V. At least that one is a small battery, so maybe it'll just make a small explosion
    #1794
    i wonder,
    was the engine running when it happened?
    was the battery being charged when it happened?
    if 12 am, my guess is, everyone, including the battery, was asleep. so why did it explode?...
    'buti na lang, the battery clamp was there. debris could have traveled farther and hit something else...
    parang yung mga air crash investigation...
    a little spark brought down the entire giant airliner...
    Feb 2019
    #1795
    Belated Happy Birthday Bro CB!
    Feb 2019
    #1796
    i wonder,
    Im not sure I have to chat with the owner to confirm. But seems like a short circuit inside (plate accidentally touch each other) or by accident outside (positive and negative touch) that could cause that kind of explosion.
    Jan 2009
    #1797
    Yes and no.
    The first time I charged the battery, I left it for close to three days. Since naka Bluetooth yung charger, I was able to monitor the progress from inside the house. Nung 14.61V na at less than 400mA nalang charging current, I turned it off.
    I turn on the charger roughly once a week since. This time, topping off only takes a few hours nalang.
    So to answer your question, yes I leave it clamped on but I turn it off remotely once the charging voltage reaches 14.6V and the charging current below half an Amp. This is to reduce the chances of gassing.
    #1798
    Yes and no.
    I see. Ako kasi i leave my ctek minsan weeks if hindi nagagamit yung sasakyan
    #1799
    i wonder,
    Actually madami ng cases ng sumasabog. Mostly nakikita during starting daw bigla nalang kaboom.
    TY bro
    TY bro
    #1800
    is amaron a sealed, airtight battery?
    walang breather?
Amaron battery
