Page 157 of 229 FirstFirst ... 57107147153154155156157158159160161167207 ... LastLast
Results 1,561 to 1,570 of 2282
    Mar 2004
    #1561
    So this guy last time, removed the terminal to check the condition of the alternator. According to that guy, if the engine dies then the alternator is busted.
    If I may go off topic, what's the best way to check the alternator?
    A competent mechanic would check the voltage output ...
    Jun 2014
    #1562
    Any idea saan makakabili ng amaron battery for altis 2011? May nacheck ako na price 5k sa ibang autoshop. Baka lang may alam kayo na mas mura. Salamat
    Dec 2017
    #1563
    Quote Originally Posted by paolorenzo View Post
    The original Amaron was purchased 3/14/2014, then I claimed warranty August of 2015 (16 months). Replacement was given 9/4/2015, then busted today 5/8/2018 (32 months).
    While sulit naman for the total length, it just doesn't live up to the initial hype of longer lifespan (they said nuon last battery for the life of the vehicle).
    Marketing hype.
    I'll just stick to good 'ol Motolite.
    #1564
    10 month old amaron
    Ok lang ba na nasa 10.xx - 11.xx yun voltage drop, when starting?
    https://youtu.be/sfUNCe99EoA
    https://youtu.be/tUPjtWDdy6g
    Sent from my SM-C900F using Tapatalk
    Feb 2012
    #1565
    Reminder ... NEVER remove / disconnect battery from vehicle while the engine is running ... the car battery acts as a large capacitor to regulate the voltage ...
    That's what I thought when I read this statement below. With no battery acting as a "sink" or regulator, the alternator will be putting out probably more than 14V-16V which isn't good for the electronics of modern cars.
    Apr 2008
    #1566
    The first Amaron (a HiLife 3SM) we bought last 8-6-2016 has just passed the 21 month warranty period this month. Despite suffering two discharges from faulty alternator, still gives a satisfying one click start every morning. So far so good...
    Sent from my SM-G900I using Tapatalk
    Dec 2017
    #1567
    Quote Originally Posted by gearhead000 View Post
    It just so happened that I'm so used with old models that what I know are somewhat outdated.
    For example with this Isuzu I used before, you can actually start it within a battery. I think modern diesel engines won't run with a totally dead battery, much without it, since it needs power to open the solenoid valve for the fuel supply.
    Dec 2015
    #1568
    Just visit the amaron website merong list of branches where you can buy.
    Sent from my ASUS_X018D using Tapatalk
    Jan 2013
    #1569
    Di na ba pwede ipang start ang hiram na good battery tapos balik yung diskargado na battery while engine is running para kumarga na?
    Old school hack namin dati yun sa mga jeep/barang na diskargado.
    Need to update knowledge base na rin haha
    Sent from my ONEPLUS A3000 using Tapatalk
    Aug 2008
    #1570
    Quote Originally Posted by remzam View Post
    The better way to do it is to jump start the car with jump starting cable. That way you won't swap batteries anymore
Amaron battery
