Page 156 of 229 FirstFirst ... 56106146152153154155156157158159160166206 ... LastLast
Results 1,551 to 1,560 of 2282
    Mar 2004
    #1551
    Quote Originally Posted by paolorenzo View Post
    Ayoko na talaga sa Amaron. My 3smf installed on 9/4/2015 is again dead. Nag lobo na sides. To think this was a replacement unit. And weekly top up with Ctek battery charger.
    Maybe there is something wrong with your vehicle's alternator or charging system ... did you ever remove/disconnect the battery while the engine was running? ...
    Mar 2004
    #1552
    Reminder ... NEVER remove / disconnect battery from vehicle while the engine is running ... the car battery acts as a large capacitor to regulate the voltage ...
    Dec 2017
    #1553
    So this guy last time, removed the terminal to check the condition of the alternator. According to that guy, if the engine dies then the alternator is busted.
    If I may go off topic, what's the best way to check the alternator?
    Jan 2018
    #1554
    That test worked back when cars didn’t have too many electronics. If you pull out the terminal with the engine running, you’re letting your electronics to receive max volts which can end up frying them if they can’t handle it.
    Best test is to use a voltmeter. Voltage should read between 13.8 to 15.3 with the engine running and nothing else turned on.
    Dec 2017
    #1555
    Panasonic naman.
    I'm also using CTEK battery charger, but not for Amaron. I'm using it for the factory issued battery. Perhaps I'll update this CTEK two years from now.
    Quote Originally Posted by SpinCycle View Post
    That answers my question, thanks.
    Nov 2007
    #1556
    Panasonic naman.
    How many months did the original and replacement batteries each last?
  7. #1557
    The original Amaron was purchased 3/14/2014, then I claimed warranty August of 2015 (16 months). Replacement was given 9/4/2015, then busted today 5/8/2018 (32 months).
    While sulit naman for the total length, it just doesn't live up to the initial hype of longer lifespan (they said nuon last battery for the life of the vehicle).
    My stock battery on the Revo lasted 44 months, and we know low end lang mga stock batteries. With Amaron and the hype, I really expected 4 years. Alaga ko pa with distilled water after warranty, and regular charging.
    Mag tiyaga uli ako sa hindi mf, kasi ok lang naman mag regular maintenance. Half the price pa. Surely, 2 non-mf units will outlast 1 mf unit (no pun intended - Outlast brand has gone to the dogs).
    #1558
    actually, i am not really sold on the amaron's superiority.
    just perusing these pages.. may good, may bad.
    the reason i buy MF, is to avoid the white, corrosive salt that sometimes develops above "regular" batteries.
    Nov 2007
    #1559
    Yup, non-mf lasts longer than mf batteries. Manual topup na lang ng distilled water. Mas mura pa.
    Under motolite ba ang outlast? Or a totally different company?
    Besides motolite and panasonic, maganda rin ba ac delco or GS batteries??
    #1560
    Panasonic naman.
    plano ko bro, buksan na yun sakin after 1 year (17 months warranty); baka kasi kung kailan patapos na warranty eh tsaka naman tuyong tuyo na yung tubig hehehe
Amaron battery
