Older old cars used electro-mechanical voltage regulator which were generic or not precise. You had to tailor or tune the voltage regulator to the car's alternator, expected electrical load and battery size. In most cases, it also varies with the knowledge and skill level of the mechanic or technician. The14 volt in question is too low of a system voltage for the modern car.
Sir paclarify what you mean by
"The14 volt in question is too low of a system voltage for the modern car"
The common passenger car runs at 12 volts to a little higher than 13v.
A fully charged automobile nominal 12 volt battery actually has 12.6 volts at around 70°F and battery electrolyte specific gravity of 1.265, to charge the battery, the system voltage has to be at least 13 volts but at that voltage, there is a risk of undercharging since there are a couple of variables as you drive. The conditions of driving varies the voltage unlike that of a power generator that is designed to produce a linear output. To prevent undercharging, the system voltage is raised up to as much as 15.1 volts in some Toyotas. Many will think otherwise but please do some research. Similar to your bank account, you must have more money than how much you intend to spend.
won't that 15.1 V have a negative effect on the electrical appliances?
Hehe my near 40 year old reliable had one of them regulators that was separate from the alternator.
When the alternator conked out i replaced it with alternator that had the built in regulator IC. It was from a rayban galant, i think.
13.8V is the ideal float charge V for any 12V battery system while 56V for 48V system.
May digital car batt charger din ako nabili from a fellow tsikoteer pero hindi ko pa din nagagamit.
when you look into the abyss, the abyss looks into you
Not really applicable to all 12v system.
Some system uses Ca-ca battery and can run as high as 15.5vdc.
yespo. personal pride. but those were times when assembling one was a bit cheaper to buying one, that is, if one could find one to buy.
today, things are so mass-produced, it's easier and cheaper to buy the more streamlined commercial product.
take the ctek. i can't possibly construct one that looks as compact, as sleek, and as cheap, as that one.
