Page 8 of 8 FirstFirst ... 45678
Results 141 to 148 of 148
    Jun 2005
    #141
    i do not remember, what else that belt powers.
    the alternator... the power steering?..
    if just the alternator, you can drive it for as long as there is enough power in the battery to fire up your engine and your aux fan. if your trip is malapit naman, you may just complete it before something really bad, happens.
    that is, assuming you can start the engine. the more times you start it, the shorter the above distance will be.
    but if your belt also powers the power steering (which i believe it does), i would not recommend driving that car on the street. it is very very difficult to move that manibela without the PS steering.
    I think damay ng belt na yan ang water pump
    Sent from my MI MAX 2 using Tapatalk
    Oct 2005
    #142
    Quote Originally Posted by sirkosero View Post
    happened to my 2005 lancer gls recently. alternator belt broke. do not try to run it. it is connected to the water pump. aside from draining and possible damaging your battery, it will cause your engine to overheat. better buy the belt and bring a mechanic back.
    Sep 2018
    #143
    Quote Originally Posted by deckssantos View Post
    mga boss newby lang patulong naman po naputulan ako ng alternator belt pede ko pa b maitakbo yung kotse papunta ng talyer para mapagawa ok lng kya yun ,baka kc tumirik sa kalsada e thanks po...... mitsubishi lancer 2003 cvt MX po kotse
    The alternator belt is important as this accessory provides power to important vehicle systems. Driving a car with a broken alternator belt can be risky as it can affect your car's functionality. Broken alternator belt can lessen your capability of steering the wheel, it can also lead to an engine overheat and can cause the car battery to die. In your case, driving to your trusted car shop can be risky. What you can do is to call your trusted car shop for assistance or you can book a maintenance valet service. Hope this helps!
    Nov 2018
    #144
    Quote Originally Posted by SRGuy View Post
    sir wachia, Rey's Electrical Cubao ba ito?
    Yes, it's the one in Cubao.
    Oct 2023
    #145
    Nasira ang IC ng alternator so nagpalit ako ng bago in less than a year nasira. natanggal ung bolt and nuts nung harap na kinakabitan ng fan belt. bumalik ako sa shop nun ang sabi pagpapalitin lng ung unahan n part ng luma kong alternator since wala ng thread at wala ng nut.Pwede po ba un? pa help po
    Sep 2008
    #146
    Matagal na kami nagpapagawa sa Rey Auto Electrical Shop Cubao sa 15th Ave. Mahusay nuon.
    Quote Originally Posted by rosypearl View Post
    Dalhin mo kanila yock's auto electrical repair shop. Sa cubao Sila Banda along edsa. Magaling Sila at doon outsource Ng mga ilang casa alternator problems Ng mga kliyente nila.
    Kung nasa ncr ko Sila Ang best bet ko sa experience ko. Dinayo ko pa Sila from the south.
    This is correct sila expert sa alternator.
Alternator Repair
