Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 148
    Feb 2005
    #21
    Sir Theveed,
    Ishin Denki is mostly auto electrical parts ... starters, distributors and alternators.
    Feb 2005
    #22
    Sir Theveed,
    Ishin Denki is mostly on auto electrical .. Alternators, Distributors and Starters for most car brands and make.
    #23
    Ah ok... OK sila, dapat pagpartner sila ng Evercool :D
    #24
    may alternator for old MB application ba? :D
    #25
    Mike, naghanap na ako, wala hehe... pero baka sa friend ni wax pwede pa fabricate.
    Balak ko nga dati kuha ako ng Ishin na 90amp tapos fabricate bracket nalang kesa mag 18K na bosch hehe. at least bago
    Jul 2005
    #26
    wax,
    just what theveed said, mas cheaper kung directly bibili sa ishin. you're the guy who has contacts there, so ganun na talaga price ng alternators nila? pwede pa ba matawaran yun?... nakausap ko na neighbor namin & he'll help me remove my alternator and we'll bring it to the nearby electrical shop, depende sa diagnosis, kung talagang malaki na ang sira, i will opt to buy a new one nalang, yung quality alternator like ishin denki para walang problema. Thanks
    Nov 2003
    #27
    Does anyone here have contacts to the plant or main office of Ishin Denki.
    Pls PM me contact details.
    Thanks
    May 2004
    #28
    I had my Safari TD42 alternator repaired .... voltage indicator revealed alternator not charging.
    Went to Mang Anselmo (Kagawad) ... location Roosevelt Pantranco infront of the Ice Plant ....
    Replaced Diode/rectifier, alternator bearing, carbon brush, stator, .... total cost including labor P4,100 .... it's good as new!
  9. #29
    cocontribute ako dito, suking pagawaan ko to, di lang alternators, starter at electric motors pa..ac/dc
    FARGO
    718 quirino h-way
    san bartolome, nova, q.c.
    (right side when going to nova, lampas ng volvo-sign at nung intersection going to holy-cross, between sila ng glass/alum shop at vulcanizing shop.)
    272-7630, si fredie roque go lang po hanapin nyu...
    ps > kung papagawa kayo ng alternator ng sasakyan, dalhin nyu nalang yung buong sasakyan, para sila na din mag-kabit at magpapatino ng electrical nyu.. they're the one who put the 120AH bosch alternator on my maxima at yung nag-convert to "built-in IC-regulator" ng alternator ng liteace ko... mura sila manigil, pero parang palit piyesa kayo (kung sira malaki alternator mo, papalitan nila ng refurbished nila, kasama na ang kabit at conversion ng socket/bracket if needed) at pa-sked muna kayo kasi maliit ang place nila...
    May 2005
    #30
    Quote Originally Posted by eidref2004 View Post
    ayos dinn jan ,nagpagawa na kami dati ng alternator (palit bearing) noon
    lapit daw nakatira mga dancer ng Klasmeyts jan
    ^paano malalaman kung sira ang bearing ng alternator? maingay ba? apektado ba ang electrical system mo pag sira iyon
    #32
    Pag sira ang bearing it can cause a wobble that could cause the rotor to scratch/rub the stator. Maliit lang ang clearance in between.
    ^well there's no obvious wobbling there yet but i find the noise level coming from that area louder than usual. di kaya nawala mga lubrication lang ng mga iyon pagkatapos ko mag pa-engine wash (w/ degreaser)?
    #34
    Sealed ang bearings ng alternator.
    If it sounds like walang lubrication then that becomes a real problem.
    A visit to your suking electrical shop is in order.
    A stuck up bearing may eat up the portion where it seats.
    so you think the increased noise over there is not a bearing problem? i mean there's no metal grinding sound i hear but the noise coming over there has definitely upped my paranoia
    #36
    What type of sound are you hearing?
    Belt noise?
    Pulley noise?
    Vacuum pump(diesel)?
    Carbon brush?
    The bearing is still a possible culprit. Since the the bearing is sealed then its weather proof so the engine wash could'nt cause it to fail. But if your bearing is worn out already it will produce an unusual noise and drag, later on it will fail by means of a stuck up. Baka timing lang na napuna mo yung noise when you had an engine wash.
    hmmmm...i'm beginning to suspect it's more of a pulley noise. anyway, thanks for all the reply, sir. will try to inform you as to what it is when i arrive at w/ something more definite
    Oct 2007
    #38
    magkano kaya alternator for KIA pregio van '97.... looking for a alternator repair shop. lagi n lang sira ung alternator ko... pls help. thanks
    Nov 2007
    #39
    Quote Originally Posted by steadfast17 View Post
    anu existing rating ng alt mo? anyway may napagtanungan ako sa may C. Raymundo ave Pasig, surplus 90A for 4K with warranty for 6months.
    Rey electrical shop along C. Raymundo Pasig, may branch din sila sa Marikina
    Aug 2006
    #40
    Regarding sa Pregio and same rin sa mga BESTA owners ang alternator ng Kia vans is scary because our besta and pregio before naka three times na palit ng alternator brand new lagi dahil company and hindi masyado gamit binenta ang mileage is 40k plus and that was in 2003 ang delikado is when nasisira ang alternator brakes nadadamay I suggest buy a really good one and sell the van kasi dangerous Casa mismo ng Kia tinangihan at may kilala ako na dati taga Kia sinabi hindi pang Philippine condition ang mga Kia kaya nag warp ang interior ng mga yan kaya when you see a Korean van na tumirik usually sa traffic and summer season
Alternator Repair
