Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 148
    Sep 2012
    Get a second opinion... Just to compare and a quick look at olx nasa 7 k price ng brand new sa Banawe
    http://*******/57193411
    Feb 2005
    Does anyone know any suppliers that specializes on brand new alternators at decent prices?
    I've replaced my IC regulator around 3 times already and the guy at Rey's Electrical is recommending na palitan na yung buong alternator. The recent IC regulator (I bought from them which they took out from a recon) got busted only a after a few uses, kaso di na ako makaclaim ng warranty because bihira lang gamitin yung sasakyan and almost a year na lumipas.
    Problem ko is umiilaw nanaman yung battery indicator light, although ok naman yung karga, kaso they are saying its only a matter of time na hindi na magcharge ng tama. I am suspecting na baka diode lang (which I also replaced before and had a similar symptom), kaso may risk daw na baka di na kumarga pag binaba ulit and then I'd definitely need to buy a whole new one agad.
    The vehicle is an Opel, although I understand that other European brands use the same alternator (maybe different pulley lang).
    Gusto ko muna tumingin kung may mahahanap akong brand new na maganda naman price before I move on to surplus/recon.
    Thank you!
    i just saw an ad in ayosdito, for an opel vectra alternator. 3500 kesos.
    dated august.
    knowing that opels are as rare as hens' teeth here, it might still be there..
    i also know that if the wrong IC is installed, it doesn't last long..
    perhaps you should consult another alternator man... yock's, perhaps?
    Jul 2005
    Read about Rey Villa Auto Electrical Shop on this thread while looking for a repair shop for our Hyundai i10 alternator. Went to their branch on 15th Ave., Cubao and they were able to repair the diode for P1,300. Hoping it lasts.
    Jul 2013
    Quote Originally Posted by leolop View Post
    Sir, what specific component did they repair? I'm planning to have my alternator repaired at Rey's Marikina branch. No budget pa for a bnew one. What's your take on reconditioned alts? Is it better than getting one from a surplus shop? TIA newbie here
    kung may problema alternator niyo, pwede niyo dalhin din sa yocks auto electrical repair shop along edsa near camp crame. had mine fixed over there about a month ago and so far ok na ok na ang karga uli. dyan dinadala ng mga casa (cats group, daimond, honda qc., etc) ang mga sirang alternator ng mga clients nila. hanapin niyo na lang address and contact nos sa fb page nla
    hth
    Replaced this : 1463481108868.jpg
    And had the brushes changed too. Umabot ng 3k kung tama pagkaka-alala ko
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    Sep 2016
    Need help mga sirs, meron akong civic 2012 and bigla ako tinirik sa gitna. And pag iniignite ko yung starter niya, ayaw magkick in sa engine. Hindi ako sure kung tama yung term. Pero ayun dinala ko sa Honda, sabi is alternator daw ang may sira. Tanong ko lang sirs, kung possible ba masira yung alternator ng 4yrs?
    Sep 2014
    Usually pag maluwag ang connection ng battery either that or yun ecu mo tatamaan pag nag high voltage sa redondo.
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Sep 2010
    My Revo DLX model year 2002 maingay daw ang bearing Nya. Can you recommend a reliable shop to repair it in Bacoor , Cavite area.
    Quote Originally Posted by Valsky1 View Post
    sa tabi ng celestino market, along molino road near sm molino. mahusay ung gumagawa ng alternator dun.
    Aug 2015
    I have an 07' Altis with its original alternator making a grinding/whining sound. I suspect the bearings are shot. In terms of fixing it, what can I expect? Can it be repaired or should I just ask for bearing replacement? What about possible damage as a whole? First time encounter with Alternator problems, would really appreciate some help.
    Quote Originally Posted by unmarked View Post
    If it is indeed just the bearing, then just replace the bearing.
    I normally would just get a refurbished one for my Old Faithful. But not today as i an on an errand.... So next Saturday....
    Pag 12.5-13.4v * full load on accesories ng alternator, pwede ba ma repair ito para maging 14v stable * full load!
    Sent from my D5303 using Tapatalk
    Jul 2006
    Not an expert, but baka masunog ka nyan? If you need additional power, you may want to add a second battery.
    An example: Dual battery systems explained
    Aug 2014
    normal voltage is 12 V as long as yung mga nakakabit sa circuit mo ay 12 volts naman lahat, dapat ok lang.
    at a constant 14 volts, i would expect the battery electrolytes to dry up pretty fast. as in, within a week.
    May 2011
    So true with cars of the '70's and earlier. Today's cars the voltage regulation is done by the PCM using pulse width modulation with inputs from the TPS, battery temp sensor, electrical load sensor and maybe other sensors. The Toyota Prius don't even have a belt driven alternator.
    Quote Originally Posted by mina_nuka View Post
    yespo.
    the scenario we are painting, is a 70s scenario.
    May 2011
    Older old cars used electro-mechanical voltage regulator which were generic or not precise. You had to tailor or tune the voltage regulator to the car's alternator, expected electrical load and battery size. In most cases, it also varies with the knowledge and skill level of the mechanic or technician. The14 volt in question is too low of a system voltage for the modern car.
Alternator Repair
