Results 31 to 40 of 144
June 24th, 2007 12:57 PM #31
^paano malalaman kung sira ang bearing ng alternator? maingay ba? apektado ba ang electrical system mo pag sira iyon
June 24th, 2007 10:45 PM #32
Pag sira ang bearing it can cause a wobble that could cause the rotor to scratch/rub the stator. Maliit lang ang clearance in between.
June 25th, 2007 08:20 AM #33
^well there's no obvious wobbling there yet but i find the noise level coming from that area louder than usual. di kaya nawala mga lubrication lang ng mga iyon pagkatapos ko mag pa-engine wash (w/ degreaser)?
June 25th, 2007 10:21 AM #34
Sealed ang bearings ng alternator.
If it sounds like walang lubrication then that becomes a real problem.
A visit to your suking electrical shop is in order.
A stuck up bearing may eat up the portion where it seats.
June 25th, 2007 06:46 PM #35
so you think the increased noise over there is not a bearing problem? i mean there's no metal grinding sound i hear but the noise coming over there has definitely upped my paranoia
June 25th, 2007 10:04 PM #36
What type of sound are you hearing?
Belt noise?
Pulley noise?
Vacuum pump(diesel)?
Carbon brush?
The bearing is still a possible culprit. Since the the bearing is sealed then its weather proof so the engine wash could'nt cause it to fail. But if your bearing is worn out already it will produce an unusual noise and drag, later on it will fail by means of a stuck up. Baka timing lang na napuna mo yung noise when you had an engine wash.
June 26th, 2007 11:52 AM #37
hmmmm...i'm beginning to suspect it's more of a pulley noise. anyway, thanks for all the reply, sir. will try to inform you as to what it is when i arrive at w/ something more definite
- Oct 2007
- 16
March 24th, 2008 09:40 PM #38magkano kaya alternator for KIA pregio van '97.... looking for a alternator repair shop. lagi n lang sira ung alternator ko... pls help. thanks
March 26th, 2008 02:44 PM #39
March 27th, 2008 04:10 PM #40
Regarding sa Pregio and same rin sa mga BESTA owners ang alternator ng Kia vans is scary because our besta and pregio before naka three times na palit ng alternator brand new lagi dahil company and hindi masyado gamit binenta ang mileage is 40k plus and that was in 2003 ang delikado is when nasisira ang alternator brakes nadadamay I suggest buy a really good one and sell the van kasi dangerous Casa mismo ng Kia tinangihan at may kilala ako na dati taga Kia sinabi hindi pang Philippine condition ang mga Kia kaya nag warp ang interior ng mga yan kaya when you see a Korean van na tumirik usually sa traffic and summer season
