Page 19 of 25 FirstFirst ... 9151617181920212223 ... LastLast
Results 361 to 380 of 492
    Aug 2004
    #361
    Shouldn't be that hard going to Lipa... that's two full-length highways, the SLEX and STAR. I can get 14 on my 2.0 on the NLEX.
    Jul 2004
    #362
    Guys, matagal ba talaga umilaw low fuel warning light ng Optra? Minsan kasi sinasagad ko sobrang lapit na medyo nakapatong na sa red line wala pa din.
    #363
    Normal lang po yan sir glntVR. HTH
    Jul 2004
    #364
    Hehehe thank you! kanina was running near empty again nakapatong na sa redline pero la pa din fuel warning light. Nagpagas ako full tank 45 liters lang tapos yung reading hanggang paguwi ko asa 3/4 na level. Topak talaga fuel gauge ko. Dati hindi naman ganito. Pero thank you sa reply!
    Jun 2006
    #365
    Quote Originally Posted by glntVR View Post
    have it checked at any chevy dealership... in my case the gauge reached below the red line and the warning light doesnt even make a flicker, it only lights up when the car is parked inclined or tilted... or totally empty na ang tank saka iilaw siya...
    do you notice na walang drain ang fuel tank ng optra... pinababa ko iyun tank at pinatapon ko lahat ng laman ng fuel ko as in LAHAT, empty talaga ang tank... nakita ko at the bottom of the tank grabe ang dumi... later in the evening pinakarga ko ng 500 pesos, at nakita ko iyun gauge hindi tumaas, still below the red line pero nawala na ang warning light.
    btw... full tank ng optra is 60 liters
    #366
    afaik, the fuel gauge light, in most vehicles, will turn on when there is just about a couple of liters +/- of fuel left in the tank (i.e. i guess it depends on how big the engine is vis-a-vis consumption) which should be more than enough for you to go to the nearest station to fill up (i.e. maybe about 25-30 kms), except of course kung nasa liblib kang lugar, though it will also light up even when there is more fuel than that if the vehicle were traversing inclined roads.
    #367
    I had thought that most cars reserve fuel light to turn on if there is 5 Liters or less left in the tank. althought SUV's i think have a higher reserve capacity. 1.6L to 2.0L cars i was told before had around 5 liters of reserve once the light turns on.
    with a 60 L gas tank, Theoretically if your reserve light turns on and you make a refuel up to full tank, you should be consuming 55L of gas to make it reach till full tank. If indeed the reserve capacity of the Optra is 5 Liters.
    Sep 2006
    #368
    *bumpSIGGYbump*
    #369
    OT: 2nd gen crv namin dati 1/4 pa lang sa guage ilaw na ung warning!
    #370
    How much fuel is in the tank when the warning lights up depends on the manufacturer. There is no industry standard for it. But the amount is usually stated in the owner's manual.
    #371
    guys may VGis na ang optra ah! ang nakita ko lang na difference is ung dashboard pareho na sya dun sa wagon na bilog ung aircon vents! anu kaya difiference sa engine, higher HP kaya or mas matipid sa gas?? sana pwede upgrade ung mga lumang optra para maging VGis din!
    Oct 2004
    #372
    depends on the car ata yan e .... on my xtrail, it lights up when it nearly touches the E mark, on my altis, medyo 1/4 pa umiilaw na, on the rav4 pag nasa E na tsaka iilaw pero it has still s couple of liters left mga 10 or less siguro on the bmw, mga 1/5 tsaka mag ilaw na malaki e hehe so no missing na iilaw
    #373
    Guys anu ba pinag kaiba ng 1.8L at 1.6l engine ng optra?? kasi may frend akong na binebenta optra nya na 1.8 A/T eh parang gusto ko gawin kunin ung engine nya kasi sakin 1.6 na M/T! pwede kaya yun ang gagawin ko engine lang kunin ko tapos tranny ko gagamitin para maging manual ung 1.8 tapos sa oto naman nya ililipat ung 1.6L na engine! so pag ginawa ko un malamang yung ecu nung 1.6 parin kelangan ko gamitin kasi pang matic ung ecu nung 1.8!
    Anu tingin nyo guys possible kya tong convertion na iniisip ko??? Hinde kaya masyadong mahirap ung convertiion??
    Aug 2004
    #374
    The 1.8 and 2.0 engines don't really have that much more power than the 1.6 (from feedback abroad).
    For all the trouble you'd be going to, it might be easier just to turbocharge your 1.6...
    #375
    Grabe kasi pag ka underpowered nung 1.6 eh kahit nka IHE nako sa optra ko! 108hp ung 1.6L nasa 125hp naman ung 1.8L at syempre mas malik potensial nung 1.8L engine!
    Pero niky wala naman convertion na gagawin dun diba kasi pareho lang naman sila displacmemt lang naman diff. nila!
    #376
    I see some brand-new looking Optra units parked at the Rapide (?) near Ortigas. Are those brand new units?
    Aug 2004
    #377
    You have to check on Chevy/Daewoo sites and make sure they're from the same engine family.
    For example, with the Lynx, the 2.0 is a different engine from the 1.6... completely... nothing is interchangeable. Same with the Civic... the 1.8 and 2.0 are completely different engines.
    If they're the same engine family, with the exact same mounting points and accessories, and share the exact same ECU connections, this could work, except your friend would have a 1.6 AT with a non-AT box.
    What IHE have you got? I could help you determine where you could get more power... ...usually, it's a matter of restricted breathing. You could also try another ECU reflash (not at the factory) to work on your timing and fuel maps, to optimize your engine... but that's a lot of expense for little result.
    But then, there's always turbo...
    #378
    OT: hahaha... tlagang dinedemonyo moko mag turbo ha! malapit nako bumuo ng turbo pero nde sa optra sa bago kong project car!
    Ok back to topic bale hinde kami mag palit ng ecu gamitin kong ecu is ung pang 1.6 na manual kasi nde ko pede ilagay ung ecu ng matic sa manual eh or vice versa. Uumm... medyo magulo na to ah, engine lang pag palitin dude wala na iba para walang maging convertion un eh kung same engine nga sila!
    OT: sa ECU reflash naman may tropa akong nag proprogram ng mga ecu un nga lang honda lang ginagawa nya, sana kaya nya din kalikutin ung pang optra!
    Aug 2004
    #379
    I really don't know. I can't find anything about it online.
    Personally, I'd be more comfortable with finding a way to stroke your 1.6 to a higher displacement, as I don't know if the 1.6 ECU has the proper fuel maps to run the 1.8... there really isn't much tuning information on the Optra series engines.
    Redo your IHE... maybe you're piped too big or have some restrictive crushed bends. You could also port and polish some to get a little more "oomph".
    #380
    The problem with the Optra is its heavy body, but a turbo or supercharger would solve some of its lack of power but not the heavy body. That heavy body will always hamper its performance. I suggest your better off getting another car with a lighter body, maybe a toyota vios, honda civic, ford lynx RS or something else.
Chevrolet Optra [Merged]
