Results 681 to 690 of 758
November 4th, 2011 03:15 PM #681
Uh, yes, the size difference is significant, even when I went from a 255W (4.3" widescreen, same as the 205W I think) to a 1450, the screen real-estate difference was still huge.
Anyway, the major reason I upgraded is the ability of the 1450 to use pre-programmed ROUTEs (using Mapsource on the PC). Kasi, sa alternate route to Baguio pa lang, nangangarag na ako sa pag-program ng route sa 255W, e. Pag nagkamali pa ako, uulitin pa. E 16 yata ang waypoints sa route na iyun.
12k? That will get you a nice Nuvi 1450 from maloney888 on ebay.ph, man. Free lifetime updates pa! Go for it!!!
Dapat hindi heavy ang tint mo. The lesser "obstructions", the better the signal transmission. Na-experience ko rin paminsan-minsan yang "parallel road" phenomenon na iyan. It simply means that the signal has weakened, or is being bounced around, or both.
Baka naman sa TUNNELs nawala yung signal when you went from East Ave. to Mega? Normal lang kasi sa tunnels yung mawawalan ka ng signal, lalo na kung matagal ka sa loob ng tunnel.
[size=1]683/3,945[/size]
- Jun 2009
- 226
November 7th, 2011 11:46 AM #682try to update your firmware. go to http://my.garmin.com. Mine is now firmware 7.40.
i have smoked 3M tints in my windshield and super black window tints. no problem with sattelite reception except when inside the buildings.
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 8th, 2011 10:11 PM #683My gps is now working fine. Baka na bad day lang the other time. Drove from Manila to Batangas City and it did not loose satalitte reception even once. However, when I tried to update the firmware, garmin's site can not detect my unit. Is this bec I'm using a ordinary usb cable? I lost the original usb cable that came with the unit.
- Jun 2006
- 2,605
November 8th, 2011 11:36 PM #684My gps is now working fine. Baka na bad day lang the other time. Drove from Manila to Batangas City and it did not loose satalitte reception even once. However, when I tried to update the firmware, garmin's site can not detect my unit. Is this bec I'm using a ordinary usb cable? I lost the original usb cable that came with the unit.
- Jun 2009
- 226
November 9th, 2011 11:52 AM #685
- Feb 2006
- 19
February 8th, 2012 04:03 AM #686
February 8th, 2012 09:36 AM #687
is this cd-r king NAV-68 5” GPS NAVIGATOR (TOUCH SCREEN) okay to use ?? Php 5,990.00
February 8th, 2012 09:40 AM #688
February 8th, 2012 09:46 AM #689
February 8th, 2012 09:55 AM #690
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
