Page 97 of 120 FirstFirst ... 478793949596979899100101107 ... LastLast
Results 1,921 to 1,940 of 2385
    Aug 2012
    #1921
    Gary, please PM me the price of DRL installation. I bought an OEM DRL for the ASX online, plus the needed relay for auto-on/off/dim. No modification needed, we may just need to drill a couple of holes to attach the DRL pair. Thanks.
    Sent from my Galaxy Note
  2. #1922
    pipe: send me a picture sa garyq7*yahoo.com and kung saan ikakabit
    Aug 2012
    #1923
    Quote Originally Posted by garyq View Post
    Gary, sent you an e-mail. Thanks.
    Sep 2009
    #1924
    Hi Gary, do you supply DRL that is suited for Mazda CX9? Isasabay ko with stage 3 retrofit, Let me know. Thanks.
  5. #1925
    pipe: answered na
    ano: wala pa I can make one for you. Lets do the stage3 setup tapos I will make the mold for your CX9. OEM dating nyan
  6. #1926
    Stage2 projector retrofit for Chevy TrailBlazer LT
    3" bixenon projectors
    4300k D2S HID bulbs
    OEM spec 35w ballasts mounted OEM style
    OEM spec wiring harness
    CCFL angel eyes
    May 2011
    #1927
    Meron sir kayo sample ng all new avanza? Gusto ko sana mag pa install ng projector headlight. Ano po recommended niyo?
    Sep 2009
    #1928
    Sige, let's sched this month. Pa-PM how much for stage3 + DRL. Thanks Gary!
  9. #1929
    ano: ok sms mo na lang ako for the sked/pricing 0908 8183545
    just did a CX7
    got the package for the headlights and also the foglights:
    perfect fit for the headlights, parang walang ginalaw:
    output
    HL output with fogs
    Jul 2013
    #1930
    Sir gary thank you sa 70mm fog lights.. mas confident nako magdrive in high speed kasi linaw ng daan at d nakakasilaw sa opposite lane..
  11. #1931
    cadash: welcome. thanks din. post ka naman output pictures and front shot of your car.
    May 2011
    #1932
    Sir question lang po. Gusto ko magpa install sa avanza 2013. I'm a bit worried sa halogen kasi pag madami sakay sa likod parang tumataas yung aim ng ilaw dahil mabigat sa likod. If ever magpa projector ako hindi ba nakaka silaw siya sa kasalubong kung madami din sakay?
    Apr 2008
    #1933
    *Sir garyq Sir do you give an option to put a 3000k for the foglights o 4300k rin just like the main HID headlights? Thanks sir!
  14. #1934
    spyler: yes kasi sa halogen hindi clear masyado yung cutoff ng ilaw. Sa retrofit mas clear and you keep your stock up/down adjustment. We can also compensate sa adjustment kung meron kang karga lagi sa likod.
    maharot: stick with 4300k para match sa HL mo. sabay na natin fog retrofit mo
    Jul 2013
    #1935
    Quote Originally Posted by cadash View Post
    Sure sir gary paguwi ko sa weekend gawan ko ng magandang set of shots..nung dinala ko sa casa daming naginquire sakin san nakuha binigay ko nalang site mo..dc next time hahaha
    Apr 2008
    #1936
    hindi ko parin nacoconvince si misis sa fogs sir hahaha.di ko rin magamit credit card sir para sana tru paypal nalang ung fogs payment in terms ko nalang sayo sir fogs hahahah j/k excited na ako with my projectors.hindi narin ako mahihirapan sa commonwealth hehehe
    Sep 2013
    #1937
    PM sent po sir gary.
    Sep 2009
    #1938
    Hi Gary,
    I just read your Stage 1,2,3 definition in your website, I just realized that Stage 3 might not be necessary for my ride.
    Here's why:
    - My headlight has separate HI (halogen) and LO (H11 bulb in halogen projector and I already replaced the halogen bulb with HID).
    - Cutoff and light focus looks fine to me. Although I would prefer more lighting power on my LO.
    - The DRL is purely for aesthetics purposes.
    So, would like to clarify with you, do I still need Stage 3 or Stage 1 is enough?
    And how much difference in lighting power will there be before and after the retrofit (for both Stage 1 and Stage 3)? My reason for retrofit is to improve lighting power.
    Also, saw your retrofit gallery and am a bit confused between Stage 2 and Stage 3 in your previous projects. Can you simplify the difference between Stage 1,2,3? I read your definitions in your website, but the pictures confused me a bit.
    Thanks.
  19. #1939
    On a basic H4 vehicle, difference with stage 2 and 3 is just the bulbs. OEM Philips ang stage3 and aftermarket ang stage2. I only use the very best aftermarket bulbs with less than 2% return rate in 4 years! Sa oem na Philips, wala pa or zero ang napalitan ko in 4 years, going 5. Sa output, around 15-20% ang difference, mas matingkad Philips and in the long run the Philips will give you the same output over a period of time. Sa itsura walang difference sayo kasi we will use the same bezel. The HID projectors will at least double your light output since halogen projectors ka.
    Sep 2009
    #1940
    Thanks Gary for the clarification.
HID Projector Retrofits by garyq
