Page 98 of 120 FirstFirst ... 4888949596979899100101102108 ... LastLast
Results 1,941 to 1,960 of 2385
  1. #1941
    another first for HIDRetrofit.net, teaser pix of our LED tail light retrofit for the new Ranger:
    Apr 2008
    #1942
    Katatapos lang ng retrofit ko c/o Sir Gary.Maraming salamat sir, this upgrade is truly worth every peso i spent.I will be saving up for that foglamp upgrade+rear fogs sir.hehehe ty ty!
    Before
    After
    LO
    HI
    #1943
    Gary pls pm price for LED foglamps for 2014 forester.. Thanks!
    Apr 2013
    #1944
    Ganda ng tail light retrofit ng ranger!! Grrr tagal ng ranger ko!!!
    Sent from my G-Note 2
    Aug 2010
    #1945
    Gary, do you have D1S bulbs on hand? I'm thinking of going up the Kelvin scale because I'm a walking Kelvin chart at the moment (4300K OEM HL, 6000K LED peanut bulbs for parklights, and 5000K sa DRL). Since napundi na yun isang parklight ko, I was thinking of going for a uniform 5000K all around.
    Thinking of going for the Morimotos 3Fives. Ang mahal kasi ng Osram CBI
  6. #1946
    Quote Originally Posted by dblackswan View Post
    I dont have LED foglamps because they will not contribute to better lighting output. What I offer is HID projector for fog application.
    Jun 2011
    #1947
    Quote Originally Posted by garyq View Post
    On a basic H4 vehicle, difference with stage 2 and 3 is just the bulbs. OEM Philips ang stage3 and aftermarket ang stage2. I only use the very best aftermarket bulbs with less than 2% return rate in 4 years! Sa oem na Philips, wala pa or zero ang napalitan ko in 4 years, going 5. Sa output, around 15-20% ang difference, mas matingkad Philips and in the long run the Philips will give you the same output over a period of time. Sa itsura walang difference sayo kasi we will use the same bezel. The HID projectors will at least double your light output since halogen projectors ka.
    Tsaka mas mataas po wattage ng stage3. Stage 2 = 35watts. Stage 3 = 55watts. Tama po Sir Gary?
    Jun 2011
    #1948
    Sana po sir kahit sa mga lumang sasakyan magawan nyo sir. More power!
    Apr 2008
    #1949
    Here are some outside shots sir.
    SIDE
    CLOSE UP
    LO
    HI
    Sorry 50mm lang ung available na lens kaya hindi kita ung lapad nung ilaw. ipon ipon na for the projector fogs :D
    May 2011
    #1950
    Quote Originally Posted by MR_MAHAROT View Post
    SIDE
    CLOSE UP
    LO
    HI
    Sir anong stage ito?
    Apr 2008
    #1951
    stage 3 ito sir. ang pagkakatanda ko A3 Projectors (3" or 2.5"?) 35watts Philips bulb , It was fitted to use the same shroud ba yon kaya OEM ang itsura. lumaki nga lang yung mata heheheh.
  12. #1952
    jhn: by order yung D1S pero pwede naman. I also have the D1S CBIs if you like which I suggest you get and call it a day.
    xsalta: pwede naman pero meron tayong limitations.
    a. spare tail lights needed kasi matagal gawin
    b. clear lens dapat para kita na LEDs. One reason kasi is for better aesthetics
    c. the question of cost
    Maharot: 3" Koito projectors kinabit ko sayo not the standard A3's that we have. OEM na projector yan. 35w Philips ballasts and Philips 85122+ bulbs from Germany.
    Our first CX7: complete lighting upgarde for this car, vehicle specific mountings for the headlights and foglights.
    Mar 2012
    #1953
    Sir gary. curious lang ako. Ano po pinag kaiba nang A3 at Kioto oem projectors in terms of size, light width/ throw, foreground and cut-off? I've read that Kioto is used by S2000 and some Lexus and A3 is obviously from Audi. Thanks.
    Jul 2013
    #1954
    Ok na ok yang projector fogs sir ;)
  15. #1955
    Our LED tail light retrofit for the new Ford Ranger:
    side markers were also retrofitted as these are getting to be more standard especially among Ford vehicles.
    Sep 2013
    #1956
    sir how much po for Hyundai Tucson 2013? HID+projector and installation? TIA!
  17. #1957
    biggest challenge for us for this project was the space limitation and the placement of the DRL. Also the bezel for the fogs was redone as it was to plain to just have a flat shaped cover so we installed the same shroud as the HI side to add some texture and details sa fog bezel.
    Quad setup Crosswind, look was upgraded to '13 model by changing the HL, grill, bumpers and of course we did the quad setup for the headlights, DRL with dual intensity output (max at DRL function and 50% at park light function) and the fogs were transferred from the old fog housing to this with custom bezel and brackets.
    DRL
    and the tail light retrofit we did in the past
    Thanks Bri!
  18. #1958
    output pix:
    fogs only:
    HL only, LO
    fogs + LO
    fogs + LO + HI
    Apr 2008
    #1959
    ganda ng drl sa crosswind sir! pati na rin ung fogs after adding the shroud,mas nagmukhang oem.
    Nov 2011
    #1960
    Good day garyq
    question: u have idea on how the vios 3rd gen single bulb projector works? does it have moving parts to switch from low/high beam?
HID Projector Retrofits by garyq
