Sa Altis!
Mas bago eh![]()
and lastly...
Driver's view!
Low ----Take note of the back of the car's rear glass shield....
You CAN'T see it..meaning no Blurring to oncoming vehicles!
Hi
Sulit na sulit po ang mods na to! Sobrang OC yang si gary sa trabaho hehehe![]()
Nissan Navara 2009 OEM setup, as in same as what you will get sa casa BUT wider and more intense projectors. Output muna:
The fogs were also retrofitted:
Subaru Forester 2010
quad setup, 5000k bulbs, oem spec ballasts
K1 shrouds
Drove up to Baguio last night. Left Manila at 12 am and reached Baguio at 4pm. Drove thru heavy rains and fog. My FXR's cut thru them like a light sabre. The yellow fogs and hi beams also helped a lot.
Thanks SG for the suggestion
Sobrang worth it ng upgrade by garyq.
Sir gary I remembered may pinost kayo dito regarding sa pagpapa-LED nung lights nung instrument panels (speedometer, tach). Gumagawa pa rin po ba kayo nun? If yes pa PM naman po quote for Civic EK.Thanks!
Guys tanong lang po pag naka retro fit hid projectors ka hi and low hid na po ba ? kgaya ng sa honda jazz kasi ang alam ko lang H4 gamit ata ng jazz dba single bulb lang po? TIA
e2 po yung pic galing kay sir NighthawkGT
tsaka Hi/low po
mykee: done many GE and GD Jazz already. Pls see my website www.hidretrofit.net
This is a bixenon setup meaning you get a LO and HI output. For OEM spec projectors, you actually get just one output level of the bulb. At LO naka MAX na yung output nung bulb and what raises the cutoff is a shield that gets lowered down by a pull solenoid when you flick the HI switch. This is totally different from the H4 telescopic bulbs na plug and play.
