Results 371 to 380 of 2382
- Dec 2002
- 2,335
December 22nd, 2010 11:48 PM #371vrl: pwede bro and mukhang your hl needs restoration na rin. sent you a PM
December 22nd, 2010 11:50 PM #372
- Dec 2002
- 2,335
December 23rd, 2010 09:41 AM #374junkun: suggestion ko sa loob ng fog lights mo para Porsche style na DRL. I can retrofit 3 OEM leds sa loob nung fogs and wire it as a DRL. Ganda nyan
chikselog: bro I suggest getting plug in LEDs for these. I have T10s and 7443 bulbs na LED.
installed my aftermarket (bolt on) projectors sa dalawang Civic before ako mag break and eto results.
LO
HI
To explain a bit about this setup. I have worked with many types of "bolt on" projectors and to tell you frankly, bolt ons are not really bolt ons if you want to do it correctly. Many of these projectors need some modifications to correct mounting and also to maximize output. One might say na ok naman as is, pero sa akin, nabuksan mo na rin lang, bakit di mo pa ayusin and mount it properly and get the max output from the projectors. I have also tried and tested many "bolt on" projectors and the one I am using now has the best output in terms of width and intensity. I modify these projectors to get the best output and mount it properly sa headlight. The harness and the sealant for this setup is also the same as my oem package so everything in the setup is designed for long term use.Last edited by garyq; December 23rd, 2010 at 10:08 AM.
December 23rd, 2010 12:15 PM #375
December 23rd, 2010 12:57 PM #376
Ampogi nung headlights nung EG ! How much yung bolt-ons, bro ? Hehehe.
- Dec 2002
- 2,335
December 23rd, 2010 08:23 PM #378renzo: ganyan pala gusto mo
denji yan na lumang model, I dunno kung meron pa ganyan na headlamps ngayon. PM na lang kita
junkun: tatlong oem LEDs na diamond formation inside your existing fogs, ganun itsura nun. diko makita yung FD na ginawa ko. mga present Porsche naka ganun na DRL, search mo sa net.
December 23rd, 2010 10:12 PM #379
December 24th, 2010 01:02 PM #380
Minsan kasi pag sobrang traffic, iba parin ang convenience na maibibigay ng isang railway system....
Makati Subway. Completion date: 2025
