Sir gary pls pm me for the complete package less the interior for sta fe 2014, also do you do provincial service say ilo2 city? Tnx
Posted via Tsikot Mobile App
I did this retrofit way back 2010 and it is still runningPls see HIDRetrofit.net
sir gary puno na inbox mo.cannot send PM.
It's going to be a "repair" week for us as we are re-doing 2 retrofits done by other shops. First up is this FJ cruiser done 1.5 years ago. Client came in complaining about no light coming out of the projector and burnt HL lens. Eto yung itsura before the retrofit:
pag naka ON eto:
some pictures of the wiring:
tali-tali, sabit-sabit
improper sealing
and the main culprit of zero output?
burnt projectors caused by improper retrofit
so we completely removed everything that was installed by the last shop and re-did the retrofit.
OEM package on the headlights, painted the reflector housing with Dupont flat black including the shrouds. We also did something new with our LED lighting. We installed LED inside the shroud to come up with a look the client wanted. Enjoy!
Sir gary, galing ng designs mo.. Napuyat ako kaka back read.. Haha.. Im trying to find pics ng mga nagawa nyo pong accent sir other than sa mga nakapost in your website.. Sir i sent you pm po.. Hope to hear from you soon..![]()
I'm sure that heat from using 50W ballast on generic Mini H1 caused the aluminum deposition on the reflector bowl to delaminate.
Is the improper sealing the main reason for the haziness of the HL lens or was the HL resealed with silicone 1.5 yrs ago that possibly outgassed caused this?
shok: so many things caused this. the HID, sealing, etc
Have several clients asking for this and we finally developed this:
Toyota Vios 2014 Daylight Running Lights.
Get the DRL look of the top of the line Altis on you Vios!
OEM leds, with complete DRL module for auto ON when engine runs and auto DIM when you turn ON the park lights.
We also have another type of DRL mounted on the fog light bezel. Also comes complete with DRL modules and oem spec wiring harness.
2010 Subaru Forester FXT:
Another RETROFIT REDUX! Car came in with poor lighting output, burnt hl lens and spaghetti wiring. Even one reflector bowl was damaged by the previous retrofitter with a 3" crack on the sides (the projector was forced during alignment). What's worst is that the OEM ballasts were removed including the ignitors and replaced with cheap ballasts! We restored the lens, installed our OEM package including the OEM Matsushita ballasts and completely brought back the wiring to OEM specs. We also installed our 70mm fog projector retrofit as the previous shop installed bolt on bulbs on the stock fog housing.
Above Subaru with the old retrofit:
burnt HL lens
ballast mounting
HL sealed with silicon
missing oem ignitors replaced with cheap ballast
old miniH1 projector
cracked reflector bowl
2014 Toyota Corolla Altis
Version2 of our custom DRL with OEM leds, dual intensity output for DRL/park light function. Now using 6 leds and some minor mounting adjustments. Applying "Kaizen" pushes us to excellence. Also our stage3 or OEM package that is fully OEM in form and function. Walang tali-tali. Everything is bracketed and mounted rigidly for long term reliability. The harness is custom made for this car and laid out same as the original harness.
