Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 152
    Nov 2017
    #81
    I'm considering buying this LED light brand from LED Lights PH for an old SUV with reflector-type halogen headlight casing. Concern ko lang baka kasi nakakasilaw sa mga kasalubong kung nasa 13,000+ lumens yung LED light tapos naka install sa reflector-type headlight casing. Ano sa tingin nyo mga peeps?
    LED Lights Ph - LED Lights Ph & PIAA LED comparison
    Sa mga napapanood ko sa Youtube hinde naman daw nakakasilaw kahit reflectorized housing dahil plug and play lang naman
    Nov 2017
    #83
    LED Lights PH is selling the Cree XHP 50. Saw this youtube, seems to be a good replacement for those who don't want to cause glaring to other motorists.
    The only downside I see from this product is the cooling fan. It's not durable.
    Update: LED Lights PH sells a different XHP50, not the one shown in the youtube vid Ultra White & All-Weather White XHP50 11000 Lumens
    PROS (+) Positive point of this bulb
    1) Good light patter, Low Beam cut-off is same as Halogen ( will not create glare in low beam)
    2) The Fan and Heat sink are compact ( Fits in the place of philips zes fan less bulb)
    3) Nice Built Quality.Most of the part are made up of Metal
    4) The Low beam Light pattern is Wide, covers good area of the road.
    5) Low noise from the fan, when compared to other bulbs
    CONS (-) Negative point of this bulb
    1) HIGH BEAM light should be little bit in higher angle, This is due to the design fault, Both chips are place in same level. The high beam chips should be placed below the Low beam about 1 or 2 mm. If placed below it will creat HIGHER angle of reflection on ROAD.
    2) The heat-sink sits on the clip, but it is not a issue.
    Jun 2016
    #84
    same dilemma. halogen type but wanting to put LED bulb din. any expert advice?
    #85
    Quote Originally Posted by reiman13 View Post
    problema kasi sa white led bulbs bro, kahit tama yung "filament" / source pag wala sa projector, yun squirrel finder na spillover malakas parin sa kasalubong. kahit sabihin mo tama ang cutoff, unless aim mo ng sobrang baba; na magiging useless din ang upgrade mo.
    #86
    Agree here....
    I have not seen anything yet as a true "plug and play" item...
    There will always be significant glare... Nakakabanas kapag may nakasalubong kang ganyan,- o may nasa likuran kang ganyan....
    Alam naman nila,- unless nagtat*ng*-t*ng*han sila,- o t*ng* nang talaga,- pero paninindigan na nila,- dahil lang sa perang nagastos na nila, mag-suffer na ang ibang mga motorista...
    "Mauna na kayong lahat mga d*muho kayo!"
    Nov 2017
    #87
    Isang napansin ko din na hindi ok sa mga LED headlight installation ay yung exposed yung power socket, nakasabit sa labas ng headlight back cover.
    Mukhang stick na lang ako sa halogen bulbs para hindi ako makadagdag sa mga nakakasilaw sa daan...
    #88
    Agree here....
    bro sa west service road, sa condo resort southbound. grabe na tyempuhan ako i think mga 5 (prolly more) MC naka LED. juzme side mirror ko pag nakita mo parang 2nd coming na dahil sa brightness O_o
    Jun 2016
    #89
    Mag upgrade na lang siguro ako to Philips XV or Osram NB. These 2 is for halogen lamp talaga diba?
    #90
    Yes bro.... Am using Philips XV - variants H4 and H7-lowbeam for our rides requiring halogen lamps for their headlights
    Jun 2016
    #91
    Thank you bro. How bout Osram Night Breaker Laser? Have you tried this?
    Yung Philips XV ba is white color?
    Ganun din naman original halogen
    Ilan percent brighter than OEM?
    Mar 2018
    #94
    These two are respected brands for performance halogen bulbs worldwide. The edge of the philips xv is longer lifespan.
    #95
    Bro- I have only used Philips XP/XV but bro.yebo has used the Osram NB with very good feedback....
    Can't go wrong with either of them...
    #96
    Philips XV-
    As claimed, about 130% more light vs standard headlight, bro.
    And up to 45meters longer light beam than standard increasing reaction time by up to 2sec.
    I can fairly see those in my rides with these bulbs... Either the H4 of the City/Innova and the H7-lowbeam of the GS. My other rides do not use halogen for their headlights...
    Philips XV-
    That's an all weather or White? What's the difference between the XP/XV?
    #98
    That's an all-weather bro,- but just a tad whiter than stock...
    XP is an older variant of Philips which I used on the GS in the past- about 60% more light/ ~25meters(?) more vs. OEM; While XV is the latest variant of Philips with 130% more light; 45meters more.
    Mar 2018
    #99
    What is the average life span of your philips xv sir?
    #100
    Philips XV - rated at 450 hours of operation - I have just installed in 3 of our rides,- still okay - 3 months running... But I rotate their use....
    Philips XP - average of about 7 years before I replaced each of the pairs,- after about 40KKm...
Good bright headlight to replace the stock headlight?
