Is projector retrofitting applicable in stock headlight? or kailangan HID?
You mean you want to retrofit your stock halogen reflector headlamps with halogen projectors?
What for? Halogen projectors and reflectors have practically the same level of output.
The better option is to upgrade your stock halogen (whether reflector or projector) into projector HID.
Cheapest options that are of good quality are at 8-10k. These "stage 1" upgrades use Morimoto H1 projectors which already provide much better output than stock halogen headlamps.
Here's the difference of projector halogens vs hid on our cars
2011 Toyota Venza stock halogen projectors (H11 55w OEM bulbs) Clean cut off but notice weak light output on the ground
2014 Toyota Altis with stage 1 retrofit from garyq
Both hid and oem have a clean cutoff but the output on the ground is really improved for the hid
I also watch those videos from Headlight Revolution. Even subscribed to their channel. Ganda ng supernova at GTR Brand na LED. Syempre mahal and walang nagbebenta sa pinas.
The most popular LED bulb shops here are Keon Sondra and LED Lights PH. I personally use LED Lights PH. Sadly, both of them do produce glare to oncoming traffic.
Id really like to try the bulbs from Diode Dynamics that i watched from Headlight Revolution a few days ago. From their tests on youtube hindi nakakasilaw.
You are welcome. I intentionally adjusted my headlights to point lower para hindi ako makasilaw.
I see a lot of good projector retrofit places now that are more affordable. Will probably try them next year. Sulitin ko muna itong LED Bulbs ko.
I'm planning to use yellow LED sa fog light. May nakita ko online na 12k Lumens. Okay lang ba since pointed downwards naman?
got this for 1.1k
old stock yata, a bit whiter than stock. tbh i dont see the 25m advantage over stock, and frankly im worried if ok fog penetration kung sakali maabutan ako
Pegasus Halogen 4300k H4
Windshield Medium Tint
Came from H4 LED. Tumagal lang ng 4 months.
Sent from my Redmi Note 5 using Tapatalk
