Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 152
    Jun 2012
    #21
    ^Instead of upgrading to 90/100w, you can try Philips X-treme Vision Plus or Osram Night Breaker Laser. Both are advertised as +130% more lights and both are perfect replacement 55/60w. Di mo kelangan magrelay/harness upgrade/ceramic socket.
    May 2012
    #22
    Quote Originally Posted by confused shoes View Post
    Thanks sir, i'll better check those items recommended.
    Sent from my ASUS_T00I using Tsikot Forums mobile app
    Aug 2012
    #23
    Get Philips Xtreme Vision +130% if you can. It has longer life span, +200 hours more than Osram Night Breaker Laser +130%.
    Sent from my ASUS_Z010D using Tapatalk
    Jun 2011
    #24
    Paps KS Led or Keon Sondra is even much better than my HID... 13200lumens... compare to stock... it's night and day difference.. I got it for 5k... even the fog lights is impressive....
    Jun 2011
    #25
    Aug 2012
    #26
    If you want LED, there is also Philips ZES LED bulbs. H4 is 5k per pair. H11/H16 is 4k per pair.
    Jun 2011
    #27
    Ks Fogs...
    And Headlight with fogs..
    IMO way better than any LED or headlight bulb in the market..
    Attached Thumbnails Attached Thumbnails screenshot_20170429-191726.jpg   screenshot_20170429-191739.jpg
    #28
    Ks Fogs...
    wow lakas nito, fog lamp and park lang ba nakabukas dun sa 1st pic?
    Aug 2012
    #29
    Keon Sondra is the name of the seller so he called his item "KS" LED. Actually, he is selling the same China made LED with Cree XHP-50 chip (9600 lumens) or XHP-70 chip (13200 lumens).
    At 13200 lumens, ang worry ko lang dyan is yung mga kasalubong. It is good for offroad use though and pag solo mo ang kalsada.
    Aug 2012
    #30
    I settled with Philips ZES LED because I like the design of the bulb housing. At 8000 lumens, it is already brighter than my HID. My Osram CBI Xenarc D2S HID set is rated 6400 lumens.
    #31
    Quote Originally Posted by red_one View Post
    Can you share a pic of the output?
    Sent from my SM-G930F using Tsikot Forums mobile app
    Jun 2005
    #32
    Boss may picture ka ng ilaw ng fog lamp only, walang headlights? Mukhang naka projectors head ligjt mo kaya maganda ang bato ng ilaw. Parang lunod na ilaw ng fogs sa picture
    Oct 2008
    #33
    Hi sir, are these plug and play type of light?
    Aug 2012
    #34
    Quote Originally Posted by 5000rpm View Post
    Yes, plug and play lang.
    Jul 2017
    #35
    Is projector retrofitting applicable in stock headlight? or kailangan HID?
    #36
    Quote Originally Posted by queenmj View Post
    Waste of money if you will use stock halogens. Might as well get the Taiwan/China replacement assemblies with projectors for halogens at your suking accessory store.
    Jul 2017
    #37
    Quote Originally Posted by ssaloon View Post
    More or less sir mga magkano kaya yun isang set?
    #38
    Not sure, depends on the car... a few thousands I guess.
    #39
    You mean you want to retrofit your stock halogen reflector headlamps with halogen projectors?
    What for? Halogen projectors and reflectors have practically the same level of output.
    The better option is to upgrade your stock halogen (whether reflector or projector) into projector HID.
    Cheapest options that are of good quality are at 8-10k. These "stage 1" upgrades use Morimoto H1 projectors which already provide much better output than stock halogen headlamps.
    #40
    There are hobo'r halogen replacements. The new generation plugNplay Water resistant LED bulbs now come with integral fan & without bulky ballasts. They can be had for sub$50 a pair. Most are listed for 50k hrs. So far, bang4buck mod.
Good bright headlight to replace the stock headlight?
