Results 11 to 20 of 145
- Nov 2005
- 30
January 16th, 2009 09:26 AM #11Hindi mo na makita yun road dahil sa glare coming from the HID ng kasalubong mo. Napadelikado pag kasalubong mo siya kase, hindi mo alam kung may tatawid ba na tao dahil masisilaw ka. Muntik na nga ako makabangga dahil sa nakakasilaw na HID.
Please be responsible when using a HID.
January 16th, 2009 09:38 AM #12
January 16th, 2009 09:57 AM #13
AFAIK the stock lights of some civic FD and Corolas are now on HIDs and they aren't fitted with projectors.
It really boils down to aiming.
- Jan 2008
- 4,726
January 16th, 2009 10:22 AM #14if you can't beat them, join them
yan lang ang basic principle kung bakit madaming naka HID ngayon...
sa totoo lang kung malinis headlamps mo with proper voltage and aiming , a 55/60 watt bulb is enough to see the road clearly..
its ok if you use your HID properly pero most drivers dont..
- Sep 2006
- 13
January 16th, 2009 08:24 PM #15For me, it all boils down to payabangan or ignorance. Who needs HIDs in the city? It is either the owner/driver is ignorant or unschooled or downright buang!
It is like driving an armored tank to make some check deposit to the bank!
Sana nag night rally race. Pero nasa city sila!
January 16th, 2009 09:42 PM #16
Disadvantage: libo agad ang gastos mo if a bulb burns out like what happened to my brother's Montero.
The Starex halogen headlamp bulbs cost only Php150.00/ea (same brand that's on my Patrol).
January 17th, 2009 04:14 AM #17
thanks sa lahat ng nagreply sa threads na to..i hope makarating to sa mga drivers that are not responsible in using HID lights.sna
cla..hehe!
January 17th, 2009 05:32 AM #18
atleast both vehicles have seperate low and high beams... they don't have cutoff in their bulbs... a single beam low lamp is permanently assigned to a low aim...
but a reflector with MIX of both low and high beams on a single lamp has cutoff's... the intense light will cause the low cut-off reach the high beam areas making it sabog...
and I have to speculate, if the vehicle stock lights are official international standards... does a corolla or a FD in the U.S, UK, Japan has stock HID in them?
because the vios XXX is not... dito lang ginawang XXX version yan.
Pros:
1. love the look
2. hands down...
Cons:
1. 5000k-up are less visible on the road compared to stock lights.
look at the ROAD, NOT the CAR...
blue is barely visible on the road...
2. the HID is using thousand volts, if an accident occurs leading exposure of the unit, it will electro-cute you.
if it's sabog, it ain't cool... it's rude...Last edited by rion; January 17th, 2009 at 05:56 AM.
January 18th, 2009 04:44 AM #20
advantage: you get attention
disadvantage: it not be the kind of attention you're looking for
I always get all of my button cells online... from LR44 to CR2450... for toys, remotes, TPMS, and...
