Results 1 to 10 of 95
April 1st, 2011 10:01 PM #1
from HCP website, HTH
if you have more tips just add it na lang
1. Aggressive driving this is a NO-NO (rapid acceleration and braking) sources said you can save 30% of gas if you avoid this. also its muchs safer for you and your passenger.
I say pa-tanggal nyo na yung mga tingga sa paa nyo and replace it with Helium..
2. Observe Speed Limit!! - certain cars have different speed limit but ussually gas mileage usually decreases rapidly at speeds above 96kmh.
so kung hindi ka hinahabol ng CARJACKERS wag na lang sayang ang miles ..
3. Remove Excess Weight - Oh my that subwoofer will have to go!! Avoid keeping unnecessary items in your car, especially heavy ones. An extra 100 pounds in your vehicle could reduce your Km/L by up to 2%. The reduction is based on the percentage of extra weight relative to the vehicle's weight and affects smaller vehicles more than larger ones.
hehehe tell your GF/WIFE to lose weight hahaha natawa ka?
ikaw din magreduce ka na!!!
4. Avoid Excessive Idling - Idling gets 0 Km per Liter. if you have to wait for more than minute switch off that engine :P,
and dont DO IT sa car!! mahal na ang GAS!!
baka paglabas ng anak mo may TAG na Made in HONDA
5. Keep Your Engine Properly Tuned - Fixing a serious engine problem, such as a faulty oxygen sensor, can improve your mileage by as much as 40 percent.
Wow!! 40% pwede na yan masasave mo dyan to avoid excessive idling
6. Check & Replace Air Filters Regularly - Replacing a clogged air filter can improve your car's gas mileage by as much as 10 percent.
hehehe baka may kamote na yan linisin na yan!!
7. Keep Tires Properly Inflated - You can improve your gas mileage by around 3.3 percent by keeping your tires inflated to the proper pressure. Under-inflated tires can lower gas mileage by 0.4 percent for every 1 psi drop in pressure of all four tires. Properly inflated tires are safer and last longer.
Traction!-Traction! underinflating!! hello papunta ka sa office hindi ka kakarera!! tamang pressure lang..
8. Use the Recommended Grade of Motor Oil - You can improve your gas mileage by 1-2 percent by using the manufacturer's recommended grade of motor oil. For example, using 10W-30 motor oil in an engine designed to use 5W-30 can lower your gas mileage by 1-2 percent. Using 5W-30 in an engine designed for 5W-20 can lower your gas mileage by 1-1.5 percent.
so stop using race car oil on a daily car
9. Planning and Combining Trips - Combining errands into one trip saves you time and money. Several short trips taken from a cold start can use twice as much fuel as a longer multipurpose trip covering the same distance when the engine is warm. Trip planning ensures that traveling is done when the engine is warmed-up and efficient.
With a little planning, you can avoid retracing your route and reduce the distance you travel as well. You'll not only save fuel, but also reduce wear and tear on your car.
kaya pag nag GF ka dont choose North and South dapat South and South
10. if all else fails buy a Jazz or City hehehehehe
April 2nd, 2011 12:21 AM #3
You can add this...
DIY Fuel Economy Gauge:
http://tsikot.yehey.com/forums/showthread.php?t=75735
Consider it a visual guide on how light/deep you can step on the gas pedal.
April 2nd, 2011 12:57 AM #4
Yung number 10 sobrang biased!
Pwede rin buy a diesel fed car. (Focus TDCi, Tucson R-eVGT, Santa Fe R-eVGT, Captiva VCDi-pag tumino na ang TCCI)
Most expensive alternative for number 10, buy a Toyota Prius or Lexus CT200h
- Jan 2011
- 193
April 2nd, 2011 12:07 PM #6
April 2nd, 2011 12:46 PM #7
oo nga sir ehe,, add ko din sana yung picanto/gets/echo sa # 10 ehe, may mga kakilala na kayo nag prius? or meron na sila nirelease dito?
tsaka yung bago magtake off pinapainit muna makina, kasi diba finifeed pa nang gas for idling yung engine, pag andar take off na ehe
#11. if all else fail padin, magcommute nalang ehe
April 2nd, 2011 02:47 PM #8
Yung probinsyanong kakilala namin sa Laguna binenta yung GL Grandia at Fortuner niya para sa isang Prius
Tapos wala pang plates nabangga agad sa rear door.
Sayang ang 2.2 Million Pesos.
April 2nd, 2011 02:57 PM #9
April 2nd, 2011 03:10 PM #10
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
