Results 31 to 40 of 95
April 3rd, 2011 07:39 AM #31
Older vehicles can improve their FC by using common sense strategies.
GOOD CAR MAINTENANCE!
No need for magical and pseudo science approaches. Tune up and clean up and the car starts to use fuel better. You can waste money on so-called devices (it's your money anyway) but then you do not help the "green cause" or save fuel (you just make the vendors of such crap richer).
The TS posting are the best for good FC. +10000 to TS
April 3rd, 2011 09:38 AM #32
- Jan 2011
- 193
April 4th, 2011 10:09 AM #33Originally, I was referencing air resistance of the roof rack, rather than the weight of it.
I did read a study about this a few months ago, that upwards of 10% increase in fuel consumption savings can be had by this simple step of removing the roof rack when not needed.
Air resistance is really a BIG factor along with excess weight in wasting fuel.
Other items that affect air resistance are such items as lowered windows rather than fully closed, a pick-up tailgate that is raised with no load in the back. Some wind resistant wheel covers, etc.
Every little bit helps.
Ciao!
Uncle Nick.
April 4th, 2011 11:00 AM #34
There was a study also that lowering your windows vs using the A/C will just consume the same Fuel in long-distance travelling. But if lower you're window by just a bit (esp if you have raingutter installed), it will help your FC.
Indeed wind resistance is a factor that is why for example trailers preferably should use deflectors.Fasten your seatbelt! Or else... Driven To Thrill!
April 4th, 2011 11:05 AM #35
Not necessarily. Its really matching the proper fuel for the car. Some cars work just as efficient with 93 or 95 octane while some work better with higher octane. In our case, our 93 Sentra 1.4L also runs better with XCS (more efficient and runs "lighter") as compared to when i use Xtra Unleaded or even the 95 octane of other companies.
April 20th, 2011 02:41 PM #37
Siguro, during these times na sobrang mahal na ng presyo ng gasolina, ang best tip to save gas is use the public transport....
12.9K:foshizzle:
- Mar 2011
- 44
May 30th, 2011 12:42 PM #39
Monk-owned R53
