Page 1 of 2 12 LastLast
Results 1 to 20 of 32
  1. #1
    Hi guys,
    The car manual says to use unleaded with minimum 95 octane but what happens if you use unleaded with minimum 93 octane? Is this bad?
    Which gasoline( shell, petron, caltex) has the unleaded 95 octane?
    appreciate hearing from tsikoteers.
    city
    Jan 2004
    Di ba 95 yung Petron XCS tsaka Shell Velocity?
    Yung Caltex Gold ba 93 lang? Di ko na maalala.
    Many modern engines will retard / advance their timing to adapt to the lower octane fuel. This will however result in poor fuel consumption and engine performance.
    All gasoline distributors here retail a 95 (and above) RON unleaded fuel (Petron Blaze, Petron XCS, Shell Velocity, Caltex Gold, Seaoil Unleaded, Seaoil Extreme, Total Infinity, etc.).
    Seaoil Extreme
    96+
    Petron Blaze
    95 RON
    Shell Velocity
    Petron XCS
    Caltex Gold
    Seaoil Unleaded
    Total Infinity
    93 RON
    Shell Premium
    Shell Super Unleaded
    Petron Xtra Unleaded
    Caltex Silver
    Total Unleaded
    Quote Originally Posted by baiskee
    97
    Seaoil Extreme
    96+
    Petron Blaze
    95 RON
    Shell Velocity
    Petron XCS
    Caltex Gold
    Seaoil Unleaded
    Total Infinity
    93 RON
    Shell Premium
    Caltex Silver
    Total Unleaded
    Lahat ba 'to unleaded, aside those already mentioned "unleaded"?
    Quote Originally Posted by ineedmorehp
    lahat yan unleaded.
    Quote Originally Posted by mazdamazda
    lahat yan unleaded.
    Ah ok. I thought some were leaded. Are they still selling leaded gasonline?
    Quote Originally Posted by city
    depends. If your car is equipted with a fuel quality sensor, it will adjust the ignition timing a bit. If it doesn't have one, it might run rough.
    Feb 2005
    Quote Originally Posted by ghosthunter
    san sir nakalagay yung sensor? any idea kung ano-anung carmake and model ang mga meron ng ganitong device? tia!
    Aug 2004
    Usually, there is a "knock" sensor that detects if the engine is experiencing pinging or detonation (signs that the gas is burning BEFORE the sparkplug ignites), when this occurs, the system adjusts accordingly. On some high performance cars, you can lose up to 5-10 hp from using lower octane gas, but on most "95 Octane only" road cars, you'll lose just 1-2 hp, hardly noticeable in most situations.
  11. #11
    wow..thanks for the info...i feel stupid..i thought shell velocity, petron XCs and vortex Gold are leaded...hehehe...pretty dummy...i sure have a lot more to learn..thanks for the patience guys.
    city
    Believe me, putting 95 octane or better will really be more beneficial for your car. It will run lighter and/or consume less fuel.
    By the way, Is SeaOil Extreme 97 octane really better than Blaze and Velocity?
    Sep 2005
    Quote Originally Posted by squala
    Before this was my impression too. But I was disappointed coz it did not meet my expectations that my mileage (km/li) will improve. I use vortex gold (95 octane) before, experimented on shell velocity (95) and blaze (97) but I did not see any improvement on the consumption. Now I shifted to Petron Xtra (93) with fuel saving formula, mas okay pa. 'had improved my fuel economy about 13-14%.
    Quote Originally Posted by lancer
    Economy improvements vary on a case-to-case basis. Also, you would hardly get to notice any changes if you switch from one fuel to another, because different gasolines will tend to mix up. Try sticking to one particular gasoline for at least a week, then top up with another kind, and so on. Finally, settle for the one you find the best.
    Sep 2005
    Yes, I did that. When infact not only a week but a month. I waited until my fuel tank is empty (warning light on) and gas up different gasoline type at full tank. I tried to do this twice in each type to be sure that they are not mixed up with other brands/type. Finally I settled on Petron Xtra after several tests with other brands.
    Time and time again... this has been proven to be a myth (including people working for fuel companies).
    Generally, only high compression engines need high octane fuel. And, believe it or not - low octane fuel has a higher energy content than its high octane counterpart.
    Feb 2005
    could you pls elaborate more on this subject? its quite interesting...
    Sep 2005
    My boss just bought a 2nd hand Nissan grandeur. According to the cars specs it should only use 95 or higher octane rating. The 1st owner had previously use lower octane gas. After a week or two the car wont start due to clogged fuel lines parang nag solidify yung gas (parang cholesterol nag clog sa veins). I don't know how true but this is the findings of nissan technician who troubleshoot why the car won't start. The worst part was its fuel pump were damaged and have to change it with a new ones. This cost him about 16K pesos. This was confirmed by the nissan casa technician that it was the cause of the malfunction - using low octane gas.
    Aug 2004
    Out in the boondocks. If you go very far north or south, you'll still see 89 Regular, I THINK. At least, that's what it says on the pumps, but they could be filled with 92 Unleaded by now.
    Any gasoline you buy in the metro is unleaded.
    May 2005
    Octane is just one thing to cosinder. Shell,petron,Total,Seaoil,Caltex and etc.
    Put some additive to improve your fuel consumption and engine performance like Shell Better mileage formulation and Petron Xcs this two formulation improves fuel consumption and engine performance.BTW all gas fuel here is lead free since 2000 pa yata coz of the Clean Air act.AFAIK in 2010 our diesel will be cleaner coz of that law.Syempre mas mahal na price /lt.
Unleaded 95 Octane
