Page 44 of 91 FirstFirst ... 3440414243444546474854 ... LastLast
Results 861 to 880 of 1806
    #861
    Quote Originally Posted by Honda
    Question
    Anybody heard a fuel saving device named gasmizer?
    never heard.
    Its made of cooper and it is installed between the fuel pump and the carburetor/ fuel injection. The gadget works by preheating and pressurizing the fuel through the circular movement of the piston with in the device. The same motion produces heat from the friction caused by the movement.The fuel that passes through the gadget is atomized, turning it into " Miro-spray" form before it reaches the reservior of the carburetor. The preheat fuel allows a more efficient combustion thereby reducing your fuel consumption.
    The pseudo-science is mind boggling.
    Do you think that gadget really saves fuel?
    in a word, NO.
    Apr 2005
    #862
    Thanks for answering my questions. I should have ask before I bought one. Now thier telling me that I should try it for 3 weeks with a full thank and I txt them that it should be working as soon as it is installed. Now I'm having a hard time to refund my money.
  3. #863
    Another delaying tactic? They're just making excuses. Better demand a refund sooner than later...
    #864
    I suggest if you have a lawyer, have him write a rather strong letter with emphasis in regards to the refund. It should work wonders.
    Apr 2005
    #865
    i read from the gasoline FAQ (http://www.faqs.org/faqs/autos/gasoline-faq/part3/) that maximum thermal efficiency occurs at an air-fuel ratio of 16-18:1
    since the stoic ratio is 14.7:1 that means that maximum thermal efficiency occurs when the engine runs lean!
    the FAQ didn't say if engines can run safely at this lean ratio. what it did say was that if the mixture is weakened, less heat will be converted to mechanical energy leaving heat in the cylinder walls and head. it seems that this weakened mixture is not the same as the lean mixture for max thermal efficiency, but rather beyond it (leaner). i suppose that when the engine is operating at maximum thermal efficiency, the most heat is converted to mechanical energy leaving less heat in the cyclinder walls and head. this line of thinking leads me to believe that the air-fuel mixture can be leaned out up to 16-18:1. any leaner and the engine will start to overheat. i'm not sure if my reasoning is correct or if i'm missing something and i'd appreciate any thoughts on this. thanks.
    #866
    From ABS-CBN news:
    http://www.abs-cbnnews.com/storypage.aspx?StoryId=3560
    [SIZE=3]Atienza supports Pinoy invention[/SIZE]
    Mayor Lito Atienza of Manila vowed to give support to a Filipino inventor who introduced a gas-saving device that could reduce by 50 percent the consumption of gas of motor vehicles.
    Atienza, who saw the demonstration on the capability of the Khaos Super Turbo Charger (KSTC), vowed to bring the gadget to the attention of his constituents.
    "We should be proud that we have an inventor like Pablo Planas, a former jeepney driver and mechanic, who could help remedy every Filipino’s problem on the rising cost of fuel," Atienza said.
    The invention, Atienza added, brings honor and pride to the country besides the role it would play on the spiraling oil price increases.
    Based on the studies of Department of Energy, Department of Environment and Natural Resources, Land Transportation Office and international experts, the KSTC gives 15 percent to 50 percent less gasoline consumption if installed to any vehicle.
    Planas also assured the public of the reliability the gadget brings to a motor vehicle and a guaranteed zero pollution.
    The Filipinos, according to Atienza, "would again be known to yet another invention through Planas’ KSTC. In fact it has already been the topic of discussions in other countries." Jonathan Vicente
    #867
    Quote Originally Posted by ghosthunter
    From ABS-CBN news:
    Yup, but the article writer didn't say that the Khaos thingie is being laughed about too in those same discussions.
    #868
    wala bang tsikoteer dito na kakilala yang mga politicians na nageendorse ng KSTC? kahit na bulungan lang nila na niloloko lang sila ni Planas, sila din kasi ang mapapahiya in the end.
    Signature
    #869
    From ABS-CBN news:
    Planas
    reliability? overheat, etc
    guaranteed zero pollution? where? All I know is increased NOx emissions. Not to mention their infamous taiwan test only proves that the van will NOT pass US EPA Emissions regulations.
    May 2004
    #870
    pucha... ngayon lang ako natapos... inumaga na ako... 87 pages in one sitting...
    gh: galeng galeng mo talaga =)
    honda: sayang pera mo pre... sana ma refund agad... bago ka malugi sa gas sa kababalik sa pinagbilhan mo...
    #871
    jepoy, mas ok pang tignan avatar mo kesa yung "information" about khaos. hahahahaha!!!
    #872
    I just found their new website:
    http://www.khaos.ph/
    -now with webmail! :D
    Ok yung by-line ni Planas, "Use less Gas, Get more Cash!" Yup! Planas and his investors will get more cash
    #873
    mali yata yung basa mo. i think it's actually "you don't use less gas, but get raped in the ass" :D
    Apr 2005
    #874
    mga peeps! Khaos is effective... i've tried it once sa oto ko, hiniram ko sa uncle ko for 1 week to test it... effective sya... ride ko honda SIR, before 13-14 is to 1 fuel ratio ng consumption ko, after ko malagay yung Khaos, nag 18's ako. to test it, karga ko 250 papuntang tagaytay, from pasig, nakauwi pako using di Khaos, yung nga lang, takbong mayaman ka, 80-100 kmph takbo ko naka AC. mas matipid sya kesa sa dati, khit konti nakatipid, mas pansin sya sa mga 2.0 pataas na engine displacement, sa exped, dagdag 1 km consumption. lalo na sa trapik, mga matic especially, vtec and galant. ok yung gadget yung nga lang mahal. P6,500. and narinig ko sa june yata 7k na sya.so far wala pa naman feedback, maintainance ng air cleaner ng khaos, kelangan linisin kahit twice a month. kung memeasure nyo consumption nyo, siguro marunong naman kayo magcompute, at marunong din kayo gumamit ng odometer ng auto nyo, and alam nyo naman siguro kung magkano per liter ng nilagay nyong gas. malalaman nyo na kung ilan ang fuel ratio nyo.
    #875
    Interesting, the KSTC for motorcycles looks like a simplified version of the "original" KSTC.
    Motorcycles
    Gasoline Car engines
  16. #876
    May price increase pa.
    Sep 2004
    #877
    naku...eto nanaman tyo...hehehe :fight:
    #878
    Good Lord! Look what they have lined up for the "future".
    KHAOS Super Turbo Charger for Diesel Engines
    KHAOS Super Turbo Charger for Generators
    KHAOS Super Turbo Charger for Banca Motors
    KHAOS Super Turbo Charger for Stationary Engines
    KHAOS Super Sparkplug (1 Year Guarantee)
    KHAOS Super Battery (3 Years Guarantee)
    Sep 2004
    #879
    lahat na pwde lagyan ng KHAOS ah...eroplano kya? hehehehe
    #880
    Quote Originally Posted by Racinghart
    mga peeps! Khaos is effective... i've tried it once sa oto ko, hiniram ko sa uncle ko for 1 week to test it... effective sya... ride ko honda SIR, before 13-14 is to 1 ratio ng consumption ko, after ko malagay yung Khaos, nag 18's ako. to test it, karga ko 250 papuntang tagaytay, from pasig, nakauwi pako using di Khaos, yung nga lang, takbong mayaman ka, 80-100 kmph takbo ko naka AC. ok yung gadget yung nga lang mahal. P6,500. and narinig ko sa june yata 7k na sya.
    uncle ko nagkakabit txt nyo nalang... 666 look for Nelson.
    what do you mean by "13-14 is to 1 ratio" ? Are you refering to your air-fuel ratio? IF you are, you later claimed you are running 18:1... how did you measure this? Seat of your pants meter?
    Your claim of getting increased milage on a long drive is simply because you are cruising at a steady speed. I could also get increased milage when I drive out of town with aircon on all the way.
Khaos Super Gas Saver
