Page 42 of 91 FirstFirst ... 3238394041424344454652 ... LastLast
Results 821 to 840 of 1806
    Apr 2005
    #821
    hi! i'm wary about the overheating problem. has anyone here or anyone you personally know actually experienced engine overheating due to khaos?
    #822
    just remove it pare.. imho
    #823
    Quote Originally Posted by walanjew
    how about one guy who had engine damage? Another had engine problems which went away after he removed his khaos device. Both are from www.protegetech.com
    #824
    ghost: it's protege.org, not com... :D
    Kita nyo sa Star today? Hayup, daming ads ng Alegre, Khaos (ata) and the other one... Dami talaga naloloko. May article pa sa editorial about Pinoy Fuel saving ek ek... Another fool...
    http://philstar.com/philstar/NEWS200504012604.htm
    #825
    Quote Originally Posted by theveed
    i stand corrected
    Given the price of gasoline right now, all the snakes in hiding are bound to slither out for a slice of "pie".
    Aug 2004
    #826
    Quote Originally Posted by ghosthunter
    How about the two guys from www.fordclubph.com who had running problems with it? It interferes with the MAF sensor on Ford Lynx engines.
  7. #827
    Khaos was again featured in todays Philippine Star... Mayor Belmonte wants to install Khaos in all city governemnt vehicles in QC and save millions .
    #828
    Quote Originally Posted by ILuvDetailing
    Why not Mayor Belmote install khaos on his personal vehicles first and enjoy the "benefits" of khaos under the hood?
    #829
    Quote Originally Posted by niky
    if am not mistaken... it was TJ (Blue Lynx).
    Apr 2005
    #830
    i wouldnt want my engine to overheat, and worse, to be damaged.
    this got me thinking and now im confused. i did not expect that more air will make the engine hotter. i thought that more gasoline will make the engine hotter. :question: isnt my thinking right?
    #831
    actually, more gas (or rich mixture) will make your engine run cooler.
    Apr 2005
    #832
    this is interesting. pls let me know if any of my assumptions or reasoning is faulty.
    on the one hand:
    more gas means more power.
    more power means a hotter engine.
    therefore more gas results in a hotter engine.
    is this reasoning incorrect? isnt this what happens when you go up a long hill?
    on the other hand:
    gasoline has a cooling effect much like alcohol has on the skin.
    more gas has more cooling effect on the engine.
    therefore more gas results in a cooler engine.
    is this why the engine runs cooler? or is there some other explanation?
    any info will be appreciated. thanks!
    #833
    on the one hand:
    on the other hand:
    Assumptions are correct except you missed one thing, load on the engine.
    Example. A 200HP engine does not run 200hp all day long without overheating. Anyway, so for the same load on the engine, a slightly rich air-fuel mixture will run cooler than if it was running with a lean air-fuel mixture.
    Also a slightly rich mix will create a flame barrier between the cylinder walls and flame front inside the engine. A lean mixture will result in a thinner flame barrier. I read this somewhere... cannot remember the website source at the moment.
    #834
    gasoline per se doesn't make an engine run hotter or cooler. rather it is the air:fuel mixture which determines that.
    engines are designed to run on a specific range of temperature. it needs heat to properly combust the air & fuel. but too much heat and your engine will blow up (unless all of your engine innards are made of ceramic).
    more air / oxygen -> better combustion -> but more heat -> less reliable
    most engines nowadays are designed to run from stoich to slightly rich. this is to ensure engine reliability and to ensure that the catalytic converter will work.
    Apr 2005
    #835
    hello again. i tried searching the net to understand this lean=overheat thing. many sites state that a lean mixture will cause an engine to run hot or overheat but not one site (of those i visited) gave any explanation as to why the engine runs hot when the mixture is lean. perhaps you guys know of a site that gives a good explanation? many thanks!
    Sep 2004
    #836
    Planas was on ANC, claiming that idling engines have a 1:1 Air to fuel ratio and he is advocating a 15:1 lean burn mixture.
    To ordinary people they really won't understand this. Mixture, mixture, mixture.
    An unusually high ratio will cause engine knock.
    We really need to do a benchmark on this.
    Planas claims that there is a foreign company offering not just $10,000,000 but $100,000,000!!!
    I don't understand why he couldn't issue rights to manufacture the product to a third party, earn a quick buck, and lower the over all cost of a product which is mass produced.
    It's only Carbon Monoxide that is toxic according to Planas.
    #837
    Quote Originally Posted by pink_cadillac
    amputik...
    dyan pa lang lumitaw na ang ka-[insert expletive here] nya...
    the af ratio of an idle engine is slightly rich only... around 13-14:1
    and NOx isn't? hehehe...
    #838
    1:1 air-fuel ratio?... thats a laugh! Maybe thats true with Planas' test cars.
    Sadly this is very true.
    wow!... thats more than what Manny P. got for his boxing match!
    its to protect his cash cow...
    maybe he should inhale more CO2? hehehe
    #839
    Question!
    Is there any other person from inventionhaus who is going to try to "promote" khaos in tsikot.com?... I kinda miss the action... hehehe
    Dec 2003
    #840
    wala na they gave up, never to come back it seems but i may be wrong baka may sumulpot bigla hehe
Khaos Super Gas Saver
