Page 37 of 211 FirstFirst ... 273334353637383940414787137 ... LastLast
Results 721 to 740 of 4201
    #721
    yup ang nangyari tuly 15 pesos lang ang difference angROI ko tuloy humaba ng one year plus 6 months tsk tsk at the rate im using it at 80 liters per month
    #722
    Well, I think the news the past couple of day have been covering the petition to roll back LPG, so I think bababa din yan.
    #723
    The auto-LPG prices has gone down a bit in the last couple of weeks.
    Any updates on tsikot.com LPG users?
    So far my car has been running well.
    #724
    I just had my car converted last week. 1.3L carburated. So far so good. Cost per liter at NAIADSS was P24.20. Is this low already?
    #725
    Quote Originally Posted by afg598 View Post
    I'm expecting it to get lower.
    Sep 2006
    #726
    What's your car? And how much was the total cost of the conversion?
    Thanks.
    #727
    Saw a white Picanto taxi kanina with LPG sticker sa likod, grabe magkano lang kaya nagagastos nya sa gaso hehe
    Jun 2006
    #728
    Open na pala yung lpg conversion place sa ortigas home depot, deside big berts. I checked the place this am. Owner was not there but was able to talk to the installers.
    Name of company: Green Autogas.
    Kit: Aldesa brand from Turkey but their tanks are locally sourced. Saw made in RP mark on the tank.
    They have 3 kinds of kits: carb, efi and sequential injection.
    I copied their price list, negotiable daw sabi nung installer.
    Carb 24,000
    EFI 27,000
    Sequential injection ( comes with ECU, and injectors ) 4 cylinder 52,000, 6 cylinder 68,000, 8 cylinder 90,000
    Here is the link to the website of Aldesa
    http://www.aldesa.com.tr/aldesa/en/default.asp
    Jun 2006
    #729
    Ito pala yung perodic maintenance schedule of lpg kits. Taken from Aldesa website. I copied and paste it for your convienence.
    http://www.aldesa.com.tr/aldesa/en/c...4&CID=13&PID=5
    "Possible Failures With Your LPG System
    Periodical Maintanence
    The electrical installation shall be checked at every 10,000 kilometers and for the existence of any oxidization on connections.
    Caustics and impurities trapped in the evaporator-regulator shall be discharged by opening the drain plug at every 10,000 kilometers.
    The filter in the LPG electro-valve shall be cleaned at every 10,000 kilometers.
    Repair sets for electro-valves and the evaporator-regulator shall be changed at every 10,000 kilometers.
    The state of the main hose and connection components should be checked.
    Stage 1 and 2 pressures of the depressurizer should be checked.
    Any filth buildup in the hole counterbalancing the pressure on the diaphragm should be checked" Quoted from Aldesa website.
    #730
    Quote Originally Posted by userfriendly View Post
    Actually the pricing for sequential injection isn't that surprising. Auto_xer and I did a comparitive price study if we built an automotive LPG system using nitrous oxide kits as the starting point. The pricing came out somewhat similar.
    #731
    Hello everyone
    (I didn't read the entire thread, please don't kill me hihihi)
    I'm just wondering how much ang conversion to LPG? Let's say for Vios J or Sentra GX (both will be brand new, 1.3L, pang taxi). I'm afraid na pag hindi ako nag LPG, the drivers will ask for a much lower boundary.
    Also, baka may ma-refer kayo na mahusay magconvert to LPG.
    Thanks mga boss.
    #732
    Quote Originally Posted by Bry View Post
    Hello everyone
    ok, we'll just do it short of kill you...
    Basically the prices based on NAIADSS:
    carb: P24,000
    efi (1.6L and smaller engine displacement): P28,000
    BTW, it is possible to negotiate a slight discount if you have more than one car to be installed with their LPG kit.
    as I see it, you should go to a LPG installer that is nearby because you will be sending your cars there periodically for adjustments or retuning of the LPG system.
    #733
    Quote Originally Posted by smdelfin View Post
    Thanks.
    my car is a sentra 1.3L FE. Conversion at NAIADSS was P22K. So far on my first full tank of 50 liters (85% of 60 liter tank) has ran 320km on the trip meter and the reading on the digital guage says 35% left. . This is daily commute QC to Makati 9-5 work.
    I'll wait for 3 cycle full tanks before I give my verdict on cost savings versus petrol.
    My butt dyno tells me a slight power less for RPMs higher than 2,500 but not discernable below that.
    #734
    if you would like to get back some of that lost HP, you can adjust your ignition timing by advancing it five to ten degrees more than factory setting.
    Note: if you do use regular gasoline with the ignition setting advanced, the engine will run rough. But if your car does have some sort engine knock sensor, you can savely switch fuels anytime.
    #735
    that is a very good fuel km /liter rating so far the best i can squeeze out of my civic 1.6 esi with lpg is a dismal 6.7 km per liter of LPG
    i dont have the same rating as you
    #736
    to ghost hunter:
    kamusta ang km /liter mo? ilan ang rating mo??
    to chuaed:
    how about you ilan na ang km /liter rating mo?
    did you get your tank checked already is it still carrying more than 50 liters on a full tank?
    #737
    Quote Originally Posted by topgun View Post
    to ghost hunter:
    Just doing roughly 6.5 km/L ... all city driving with A/C on. I haven't tried going out of town yet.
    #738
    The power loss doesn't really bother me that much but if I were to advance the timing, will it affect the engine operating temperature? How about fuel economy, will advancing make it more efficient?
    #739
    This is getting really wierd.
    On petrol, I used to do average 7.58km/l. Actually one time I was waiting for my fuel guage to light up before heading for the gas station and I realized the hard way that the bulb was already busted already so I actually ran out of gas!!! Good thing the nearest station was just across the street. :sweat: . The trip meter read 340km so, obviously, that's the furthest I can run my car on a full tank till empty.
    Now my trip meter reads 398.7km and the digital guage still reads 30%! I haven't changed my route to and from work, no long distance trips and same driving habits.
    #740
    if you ran on LPG on stock ignition timing, it would be like running on gasoline with your timing retarded which results in less power and lower engine efficiency. In theory, you should have a percentage gain in fuel economy.
    The reason why you need to advance your timing is because the flame front of LPG is slower than gasoline. So LPG needs to be ignited earlier than gasoline.
Auto-LPG Conversion Thread
