Quote Originally Posted by eikichi View Post
I also experienced the same situation and had it checked. Dinala ko sa Greenfuel yung sasakyan and was informed na walang problema yung solenoid ko. Sabi sakin try checking the fuel pump or the injectors. I had my car checked and lo and behold, may problema nga sa injectors ko. nung kinalas yung unang injector, barado na sya. All the injectors were clogged with solidified/dried gas daw. Parang alkitran nga. Color was dark brown and emitted a rich foul smell of gas. Nilinis lang muna yung 4 na injectors using gasoline and dried using compressed air tapos binalik ulit. After that, ok na ulit andar ko using gas. Dapat pala inuubos ko yung gas reserve ko more often. I only use gas before shifting to LPG and before turning off the engine when I get home. Maybe you can try having it checked as well. Baka dun din ang problema.
Sir eikichi, where did you get your injectors checked and cleaned? Sa casa po ba?
