Quote Originally Posted by daneklog View Post
Just came from a day of diagnostics at Greenfuel yesterday. Medyo sumakit na ulo ni Tolits on how to make my Adventure works well again. Nagbaback fire kapag nag aaccelerate ako when using LPG. One of the possible cause he mentioned might be the hi-tension wire. Per tolits also, mine will be the 1st case of SGI na nakaka encounter ng ganitong problema. He used the tester in the diagnosis and found out that the 2nd wire shows "no reading". Will this be the main culprit? Just had my change oil, spark plugs and air filter last December. Tolits also replaced the injectors and railings.
In my experience with high tension wires, they tend to fail after a year or so after installation. They either "leak" (failed insulation) or conductor breaks at the sockets by mechanical failure or corrosion.
Stock wires are still better unless you have fully upgraded your engine's ignition system.
