Quote Originally Posted by eikichi View Post
I'm also experiencing problems with my car. I've had days when hard starting occurred repeatedly. Last night, I filled up my car with LPG and this morning, I did have this hard starting issue again. I tried starting the car and pressed on the gas pedal slightly and when the engine ran, it sounded like a drowning engine. Similar to the sound when a carb engine is flooded with gas but mine is fuel injected. Switched to LPG and got the same result. Was advised to let the engine run for a couple of minutes while stepping on the accelerator pedal to burn the excess gas.
I also have the same experience last week after na stuck ako sa INC traffic jam. driving a 10KM stretch in 7hours. anyways, i also suspected that the solenoid is partially open when i start my car in the morning. nangyari lang ito 2 times and after that normal na ulit ang start ko whenever the engine is cold.
dati kasi napag laruan ko yung switch. cold engine, nag start ako sa gas then after a few seconds auto switch to LPG, then binalik ko ulit sa gas. dito ko na experience na parang lunod ng gas yung carb.
yung na experience ko recently parang palyado ang makina, kumakalog yung engine, pati dashboard pati tambutso. pero after mga 3 minutes bumalik na sa normal. hinde ko tuloy alam kung anu naging problema. ipapa check ko na rin sa greenfuel, this month na kasi ang 1 yr ng kit ko.
ang hinde ko lang talaga mahuli sa lpg is yung pag adjust ng idling, i tried to adjust a few times pero kailangan talaga ng practice. the rest ok naman.
