hinde pa pwede i verify by changing the affected tension wire lang muna from other cars. kasi mahirap naman bumili ng bago then kung hinde mawala ang problem sayang ang pera. mahal pa naman ng high tension wires.
update mo na lang kami sir. thanks.
Why not just use the original wire-set that came with the vehicle to test if the source is the high-tension wires currently in use?
question lang po:
1.0 has anyone tried using resistor type plugs? if yes does it improve your lpg performance?
2.0 how about iridium and other type of spark plug aside from the plugs recommended by OEM. may nakagamit na ba and does it also improve your lpg performance.
reason for the question:
im using lpg for almost 5 months now with stock plugs * 7K km running on lpg. the problem now is when the car is idling without AC, nag ddrop and RPM to the point na mag stall na yung kotse. during the first 3 months naman hinde ganito.
as recommended by greenfuel yesterday (alvin) try to replace the plugs with resistor type or the 6pbs type. i want to check with lpg user first para malaman kung may significant impact ba ito otherwise i will stick with the stock plugs. Thanks.
Resistor plugs are also recommended on any vehicle that has other on-board electronic systems and as a rule, performance is in no way impaired by resistor spark plugs. Best to consult your vehicle specification booklet or search it via Internet.
Toyota Innova stock spark plugs uses (R) resistor type spark plugs (Denso K20HR-U11) because it has OB electronic system. Furthermore, I have been using one step colder Iridium (Denso IKH22 also resistor type) now running more than 10K++ kms with no hesitation and the engine runs a little bit colder too. I see not much difference using Petrol or LPG, but engine runs smoother on LPG
The only consolation of using Iridium and one step colder was extended life of the spark plugs, if you are comfortable with your stock plugs then just replace them shorter than normal schedule.
LPG prices keep getting higher. So the price difference between LPG and petrol keeps getting smaller. With the high cost of conversion, the ROI is getting longer. It seems it is now harder to convince other people to convert than it was a few years ago.
It is somewhat similar to what happened between diesel and gas. Years ago, their price difference is big, but not now.
You think that would also happen to LPG, that the price difference between LPG and gas would soon catch up to just a few pesos?
It'll get higher, but I don't know if it'll reach diesel-gas levels (and remember, diesel here is artificially cheap due to government subsidy). LPG has diverse sources, and is not reliant upon crude oil production.
The price inflation locally seems artificially induced. We'd been talking about the possibility of hoarding a few days ago, and lo and behold, the government has already caught at least one trader hoarding LPG canisters.
I'm sure there will be many more to follow.
* mile2 &GH : thanks for the advice. will replace the plugs with a step colder, check ko sa suking tindahan. update ko kayo. maraming salamat
Curious lang ako...so dun sa mga meron real-time fuel consumption meter (e.g. Fortuner), I guess it would be interesting to see the "mileage" you're getting on the display when running on LPG??![]()
I have MID in Innova same with other IMV (Fortuner and Hi-Lux), the display is the same as it calculate base on the matrix of Air-fuel mix, electronic gas pedal movements, electronic throttle, cam/crank MRE sensor and emission sensors. Basically, it does not include in the matrix the gasoline tank meter as it will not give accurate reading all the time when the car is moving.
So when on LPG mode, the MID average Km/li reading is just as normal when in petrol. I usually get a minus 1-2 average Km/li reading when on LPG.
It won't be accurate. It's guesstimating based on injector duty cycles (based on the ecu signals sent to the injectors, not based on whether the injectors are working or not), and as the air-fuel ratios are different on LPG, and the LPG injectors are "trimmed" to a different calibration than the gas (even with the same AFR based on O2, since stoich is different for LPG and gasoline), it'll always be a little off.
hi smdelfin! actually the shortage is not because of hording etc. its because of Europe buying LPG now that its winter time. LPG is a by-product when you produce gasoline and diesel so i don't see it having shortage issues due to production and its prices should return to normal levels soon enough.
Good evening to all auto lpg users. I have been using it for 5 moths now.
My friend said this morning that there was a news of a taxi in makati whose lpg tank blew. Please shed light on this matter. Thanks
good evening. Please shed light on what caused the taxi in makati that is running in lpg that blew up as per bomboradyo report last feb. 2. TY
