Originally Posted by
kapitan88
I am having this kind of problem now. Anyone tried to measure the voltage supplied to the solenoid? My solenoid for the petrol is f'd up. Di nag di-disengage. Nakuha ko is 1V lang all the time, then when I tried to switch sa neutral, naka 1V pa din, while when I checked yung solenoid ng lpg line, pag switch on, momentarily 1v, then 0 na, then if i switch off, momentary 1v, then 0 ulit. Or baka mali lang ako ng setting sa tester? masyado yata mababa yung 1? (i used digital VOM on 20VDC setting).
ang side effects na nangyayari is even if i switch to neutral, hindi nauubos yung petrol sa float (mitsu carb type), kaya continues pa din ang supply, (also i dont hear yung tick sound ng solenoid whenever switching from petrol to neutral or v.v.). Mga 10-30 minutes na ganito kahirap i-switch off yung petrol line ko, then after a while na mag-init, bibitaw na din, and ok na, naka switch na ko sa lpg. Nothing unusual sa black box switcher, naka ilaw yung petrol indicator when in petrol, then all lights off in neutral, then, lpg indicator with content level if in lpg mode. Yun lang talaga ang natrace ko yung power papunta ng solenoid ng petrol, parang tuloy tuloy ang daloy.
Almost always na ganito lumalabas yung problem ko, medyo puno pa kasi ang sked ko at di pa maibalik sa greenfuel, pero next week, pasyalan ko na sila.
