Page 167 of 211 FirstFirst ... 67117157163164165166167168169170171177 ... LastLast
Results 3,321 to 3,340 of 4201
    Mar 2007
    #3321
    Quote Originally Posted by aysiyadi View Post
    What are the advantages of the split fuel system (e.g. econogas vogas split fuel system where gas is injected simulteneously with lpg) versus the SGI system? Do the advantages offset the higher cost?
    I am planning on converting a 98 camry.
    I think its safe to guess that the split-system is superior among all the SGI kits available locally. And so its price. Maybe 50% higher than the typical SGI kit.
    If I recall correctly, the only difference from the split-system is the ECU, the rest are SGI gear.
    As for the vulnerabilities of the SGI, like clogged injector due to oil contamination, maybe I'll ask them again.
    I'm inclined to have this mounted on my car, even if I have to pay extra. The thing stopping me is my employer's gas allowance which only allows me to pump up with Caltex. At wala auto-LPG ang Caltex
    As long as you're a frequent traveller, you'll be able to recover your investment and won't mind the expensive price tag.
    Paging Bigfootoz, interested client.
    Mar 2007
    #3322
    Regarding the venturi kit, do you really lose 1km/l once you convert to LPG? Like from 6km/l on petrol to 5km/l on LPG? Can it be possibly tuned to maintain its old efficiency?
    What size of tank is good for a 2.2 car?
    Where is the best place to put the filler nozzle? in the fuel tank lid or below the trunk? any pros and cons?
    Also, do all LPG gas stations accept credit cards to fuel up?
    #3323
    Quote Originally Posted by oceanrider88 View Post
    It is possible but performance will be affected if you try to maintain the fuel mileage. This is due to the lower energy density of LPG as compared to gasoline.
    Tuning your system to get the same fuel mileage will result in a leaner burning engine which will result in lower HP output.
    And lean burn has it's own problems as mentioned within this thread. Basically, its not good.
    typically 60L would be fine. You could also try to find the biggest tank that would fit in your trunk. Going too big has it's own problems like too much extra weight will result in poor fuel mileage.
    It depends in your car. I have mine beside the gasoline filler because I have enough space for it. Other cars have it under the bumper.
    At the filler, requires drilling/cutting of metal. But it's hidden and generally protected from dirt and potential damage.
    Under the bumper, no need to cut metal but filler exposed to elements and potential dirt intrusion or physical damage if it gets hit by something hard like a rock or concrete parking block.
    nope. Depends on the station. You might have to scout your nearby Auto-LPG stations to find out which accepts credit cards for Auto-LPG.
    Aug 2008
    #3324
    What is the current fuel consumption of your camry city/highway if I may ask?
    I get between 6.5-7.5 kms/liter Manila driving (QC to Makati and around QC). Have you decided which kit to install?
  5. #3325
    In my experience, Petron and SeaOil accepts credit cards for all fuel purchases (auto-LPG included). I have not tried Total, but I won't be surprised if they also accept credit card.
    Petron also accepts my fleet card for my auto-LPG fill ups.
    Aug 2006
    #3326
    I heard over the AM radio news that Auto LPG will increase pump price by Nov. 1. so better have your tank filled.
    I also filled my Gasoline tank full yesterday. It seems some stations are running out of supply. Both tanks would be sufficient for me to run for 2 weeks.
    In any case, the stand off between Oil Company and President's EO will surely hit us in the coming days, now that the world price is $80.
    #3327
    Yup, Auto-LPG price is expected to go up around P2/L with the increases.
    I was thinking of filling up my gasoline tank as well but as I thought about it, it would end up costing me more than the increase in LPG prices so I didn't.
    May 2009
    #3328
    Pwede bang mapa convert ang Revo VX200 2.0EFI?
    Tried to back read and havent seen a post that
    answers this. Di ako masyado maalam so just want
    to know from you guys.
    #3329
    Quote Originally Posted by brod78 View Post
    Check the thread:
    Auto-LPG Roll Call
    http://tsikot.yehey.com/forums/showthread.php?p=1343331
    There is one guy listed with the same vehicle converted to Auto-LPG.
    Aug 2006
    #3330
    Puede yan PM mo si paolorenzo may Revo VX2000 siya na LPG.
    May 2009
    #3331
    sir gh & sir mike thanks for the quick reply,
    i will have my revo later on, 2nd hand lang
    pero pwede na rin kasi first time ko lang magka
    kotse lols...
    sabi nung seller eh avg nya is 10km/l daw
    consumption nya from qc to tagaytay, anyways
    i dont know kung totoo yun o hindi kasi nga
    noob ako pagdating sa kotse hehehe...
    so goodluck sa kin mamaya
    #3332
    kotse lols...
    The claimed 10km/L is possible IF you are driving on the expressway or roads without traffic.
    Sep 2009
    #3333
    I converted my VX200 automatic to LPG last July, went with the old NAIDDS venturi type conversion and so far i am consuming 5 liter/km with LPG city driving. So far encountered no problem with the LPG.
    Placed my tank at the back removing 1 of the foldable seats. My wife only complains of the unusual "bottle sound" the tank makes when driving to uneven road surface.
    #3334
    Quote Originally Posted by ryanboy View Post
    You can hide the tank inside a custom made enclosure that can double as another bench seat at the back. That is how some AUV owners have done it.
    As for the "bottle sound" check if the tank hits any part of the AUV's body. Have it adjusted so there would be no impact.
    I had a similar problem when NAIADSS first installed my system. I had them move the tank 1/4 inch away from the trunk wall and the sound disappeared.
    #3335
    On a sidenote, Ferman mentioned on a used car review of the Revo on TGP before that one reason why the Revo has a relatively poor FC is because of an inherently overrich a/f mix and mentioned that tuning with the Unichip improved the FC.
    May 2009
    #3336
    *GH Oh I see at least there's some truth to what
    the seller said.
    *ryanboy, what was the FC of your Revo(city driving)
    prior to conversion? How much it cost you for the
    conversion?
    I inquired at greenfuel for the (SGI) lpg kit (thru email) and
    they quoted a price of 39k for the Revo...whew...
    thou i can afford the price my concern is how long
    will the kit or system work assuming proper maintenance
    is done?
    May 2009
    #3337
    Whats a/f and unichip? noob here
    #3338
    is done?
    My system is over two years old. Its from NAIADSS though.
    So far the only periodic maintenance needed was periodic draining of the vaporizer of the water that collects inside.
    Dec 2007
    #3339
    I think you mean 5km/liter.
    This should translate to about double (10kpl) if using unleaded/premium, because the price is about double the price of LPG. Hmm... what was your Fuel Efficiency before converting to LPG, sir?
    #3340
    a/f = air fuel ratio
    unichip = a gadget sold by SPEEDLAB which helps tune an engine's performance.
Auto-LPG Conversion Thread
