Page 114 of 211 FirstFirst ... 1464104110111112113114115116117118124164 ... LastLast
Results 2,261 to 2,280 of 4201
    #2261
    Quote Originally Posted by dieselNUBI View Post
    ok this is official na. i got 5.8 km/l on my hiway FC. kinda high isnt it?
    well i went back to greenfuel to have it retuned. ill post another FC soon.
    OT: i have an 40L tank, when i saw the red light on my guage, i still kept driving it hoping to finish it all up until the engine dies down. i drove for another 25kms with it. i only switch back to gas when i was about to drive the expressway. And i was able to filled up 37L of lpg.
    Bro what type of lpg conversion mo? Im assuming venturi, closed ba or open loop? Or sgi ba sya? Thanks for sharing your experience.
    Hopefully ma fine tune na so you can get the benefit of the system.
    Sep 2006
    #2262
    2 weeks ago, I converted my 1996 carburator Nissan Vanette in Xoom. But up to now, it's still not usable. 2 out of 4 sparkplugs get destroyed. So Xoom suggested I bring the van back to my mechanic. My mechanic tested the van using gas, the sparkplugs don't get destroyed. But when he tested it using lpg, the 2 sparkplugs get destroyed. Why doesn't the sparkplugs get destroyed when using gas? If the sparkplugs get destroyed on both gas and lpg, at least we know that there's something wrong, and the mechanic will open it up. And why only the 2 sparkplugs?
    Can you guys give some suggestions?
    #2263
    Quote Originally Posted by smdelfin View Post
    I think your auto-lpg kit is venturi-mixer and the intake is causing the last two cylinders to run a little lean which results in the damaged sparkplugs. A quickfix would be to run slightly richer to compensate for the last two cylinders from running lean.
    Also check if the venturi-mixer itself is correctly sized for your engine. If it's too big, it might result in the lpg irregularly mixing with the incoming air.
    A more long term fix is to change from the venturi-mixer kit to the SGI kit (running open loop mode) which will have an individual LPG injector fitted per cylinder. This will eliminate the lean running condition of the last two cylinders. This will be expensive and might be hard to do because of the cramp space of the vanette's engine bay.
    #2264
    Quote Originally Posted by XOOMaster View Post
    Hi Guys!
    RE: Filling Station
    Try to visit us at Timog Avenue, Q.C. station name is Autogas Petronas runned by Xoom Auto Gaz, Inc. we let you earn points and give you LPG rebates in return.
    See you guys soon!
    Thanks!
    Welcome!
    I also hope you can also contribute to the auto-lpg discussion in general here in tsikot.com... I think currently we have a member who is having a problem with his vanette when running on auto-lpg.
    Jul 2006
    #2265
    Quote Originally Posted by 1997 View Post
    Need Help... last week twice me nag pa full tank ng LPG ko sa Total Shaw Blvd... Then I notice na 2 light lang yung numilaw sa indicator... then yesterday nag pa full tank ako sa Greenfuel I notice na 4 light yung umilaw... Accurate ba toh? kasi when I computed for my LPG consumtion 4.5 KM/L lang... does this mean my consumtion is very high or Total gas station fill my tank half lang...
    suggest you look at the actual guage...the one connected to the tank...maybe your electronic guage is not calibrated properly..or maybe nag loloko yung electronic gauge mo...
    happened to me also...the electronic gauge was still full tank..but the actual gauge was already 1/4 nalang...had it checked and true enough..the electronic gaage was defective and they had to replace the ECU...
    Apr 2008
    #2266
    GH, you are correct in recommending to fill up with the same pump during your FC observation as pumps may behave differently (based on discussions from taxi drivers!). From your experience, do you have any recommended filling stations? It might be along my way. Haven't been to Clean Fuel though because it is out of my way but I'll try it soon.
    GH, am curious, how can you install an O2 for your car. (My car is an EFI w/ no O2 sensor). I've asked around (even Ford, Honda and Toyota) and they told me it is impossible since my ECU is not capable. I have a 2001 AT Civic w/o O2 sensor as well. You know any installers and how much? I am curious if I can still improve my FC. My current FC ok but any improvement is welcomed. Thanks for your help!
    May 2008
    #2267
    I just had my car converted to LPG last Saturday at GreenFuel. I noticed that they were checking each others' work and I am very satisfied with the installation: very clean and no shortcuts. They even asked me where I wanted the filler installed since I wouldn't want to put a hole in the body of the car for the filler. I stayed in their shop the whole time my car was being installed. Even Mike and Warren were very accommodating during the time that I was there. I went to Clean Fuel at Shaw for my 1st full tank right after installation and paid P760 for 32 liters of LPG. At least I can now feel that I am not robbed whenever I go for a fill up. Will update you guys when I get my fuel consumption figures.
    Thanks a lot Mike and Warren. I am the red Lovelife Corolla last weekend.
    Jul 2006
    #2268
    Quote Originally Posted by filchaser View Post
    talk to mike (greenfuel)...they can do this...i believe they work with speedlab for the dyno test...
    #2269
    Hi sir smdelphin, It would be best if you could drop by the shop again so we could check on your Vanette. We are constantly going to work to resolve this problem with your Van.
    May 2004
    #2270
    Quote Originally Posted by bigMIKE View Post
    We do not own or affiliated with this refilling station. Please tell us the exact location of "GREENFUEL" refilling station
    My mistake... clean fuel po pala...
    #2271
    I used to fill up regularly at NAIADSS station at pioneer... but now I fill up regularly at the TOTAL station located at shaw near JRU.
    It's not really which station but best to use the same as often as possible so you can get a more accurate picture of your car's FC. That or watch the tank's guage and fill to the same level each time (example 80% every time).
    SGI LPG kits can read directly from O2 sensors.
    But if you are just planning to install an O2 sensor and somehow attach it to your car's stock ECU, it's not possible unless there is an existing port for you to plug in the O2 sensor to or you would install an aftermarket piggyback ECU like SPEEDLAB's UNICHIP.
    Currently I only know that EROOM claims to do O2 sensor installations from when I talked to Mike Tagle months ago. Other shops like SPEEDLAB can also do the O2 sensor install but they did mention it will not be cheap because the sensors themselves cost quite a bit of money (makes me wonder how Mike Tagle of EROOM claims they only charge P2K for O2 installation).
    A simpler way is to have your LPG kit & engine tuned at speedlab to run better using their test instruments. I assume you are using a venturi-mixer kit?
  12. #2272
    Quote Originally Posted by Mile2 View Post
    Keep us posted on the resolution, I'm having the same problem despite I have change my spark plugs and air filter. I'm bringing also my ride tomorrow for tuning and diagnostics.
    Just came back from EROOM in Highway54 EDSA. It was frustrating for me kasi hindi lumabas yung problem, in the 30mins na ni-test drive namin. But David Do was able to simulate the problem by turning the aircon on then off. When turned off, the idle goes down very low, then dies. He was able to do it twice. So it may not have been brakes related, but rather sa aircon. It's as if when the aircon (or compressor) turns off, idling goes down too much. Weird kasi it seems na kinukulangan ng hangin yung EROOM when that happens.
    They added a hose clamp in one of the hoses connecting the aircon and the air adapter of the EROOM kit. They also tuned the actual engine idling and aircon air input to the engine. See picture below (sorry for the large image)...
    For now, ok pa siya. No signs of sudden drops in RPM, or engine dying. Will observe for the rest of the week.
    Feb 2007
    #2273
    Hi, From Iloilo city ako, Planning to convert my 1992 civic hatch 1.2 carb to LPG pero dalawa lng available na kit dito as far as I know...
    dont know the correct spelling pero Damwa korean made distributed by Pryce autogas company 18,000pesos (with 1 year warranty) and the other one is tantarini made in Itally distributed by a Taxi operator 27,000pesos (without warranty).
    so what do you think guys? sa may warranty na Korean made or sa walang warranty pero itallian made?
    Sabi nung iba same component lng italian at Korean yung kaiba is the Quality of each component mas high quality yung Italian made...
    also is this an open loop? kasi carb yung engine ko?
    ano ba difference ba nung Close at Open Loop? mdyo indi clear sakin ito...
    Thanks
    Aug 2006
    #2274
    Hi Paolorenzo,
    Good to hear that they fixed it na.
    Got mine also tuned today at GreenFuel, they did check on my injectors and calibrate the ECU. So far no sign of idling drops on braking and low rpm.
    Mike and Warren suggested that I should also have my clutch checked at casa, as somehow it affect the idling when pressing/releasing clutch.
    So far I'm satisfied on GreenFuel's after sales support, very friendly technicians and office staff and of course on-hand supervision of the owners
    #2275
    just got back from greenfuel, had mine re-tuned, kasi this past days nag degrade ng husto yung power, dahil pala sa ni lessen ko yung flow ng lpg para mas tipid (w/in acceptable power loss) and yung air filter ko na mumurahin na clogged up agad (napamura tuloy ako ng &#Y#*$) , i replaced it agad, tapos re-tuned, ngayon ok na ulit. will report ulit on my FC in a few days. 2 thumbs up talaga sa mga mechanics at kay Warren, very accomodating talaga.
    #2276
    Quote Originally Posted by ersatz0906 View Post
    I still value having some warranty. You can try contacting past customers for their feedback by asking the private car owners as they fill up at the nearby auto-lpg refueling station in your area. You might also find out if there is more than just two companies doing auto-lpg installation in your area.
    Unfortunately these companies are unknown to we cannot give you an informed opinion on which is really better. You can also inquire from the DTI if these companies are registered and certified by them.
    Thanks
    since your car is just a civic 1.2L carb... you don't have to bother knowing the difference between open and closed loop. What you will get on your car with be a Venturi-Mixer Open-Loop auto-lpg kit.
    BTW, do they offer donut tanks or just the cylinder tanks?
  17. #2277
    Thanks
    I would vote for the Damwa-Pryce kit. Since it has a warranty, I'm sure Pryce staff were officially trained for LPG installation. Mura pa.
    Since the Tartarini kit is only being "distributed" by a taxi operator, I will doubt the training of the installers since they don't offer any warranty.
    #2278
    sorry double post
    __________________
    passion for fashion? craving for savings?
    visit MAI PASSION boutique at the fashion village * Tiendesitas
    #2279
    my vote will be on the korean brand with warranty. eventhough tartarini is a known to have good quality, if the installer is a fly-by-night one, you have no assurance that it'll be ok. what's worse is it's more expensive but doesn't come with even a single day warranty at all and that's BS. worst case scenario is that you'll have your car blown before you know it.
    __________________
    #2280
    thanks guys for your comments. We also learn from our customers and we surely would like to meet everyone's expectation.
    I would also like to thank all the tsikoteers who have entrusted their car conversion with us. We really appreciate your support and patience.
Auto-LPG Conversion Thread
