Results 1 to 10 of 83
- Jul 2011
- 71
September 25th, 2018 06:02 PM #1in terms of fuel efficiency, safety, and performance which is better?
September 25th, 2018 09:34 PM #3
Performance will favour the Ecosport as that 1.0L turbo engine is quite potent. Fuel efficiency may be more reliant on driving habits. The 1.0L turbo consumes gas like a normal 1.6L NA engine with my experience on the Fiesta.
September 25th, 2018 09:42 PM #4
fuel consumption is almost the same.
as per south african specs
6.2L/100 vs 6L/100 ...
- Feb 2014
- 2,694
September 26th, 2018 12:16 AM #5
eco is taller and has more ground clearance. you could load taller objects in the boot of the eco as this pic illustrates
quality probably goes to the vitara. the ford is infamous for the faulty DCT transmissions. as well as having very low quality rear door actuators (premature failure), and fan resistor coils which lead to overheated engines
btw the body sheet metal on the vitara seems thinner compared to eco
September 26th, 2018 12:22 AM #6
hindi na dct gamit sa new ecosport.. its a traditional torque converter
September 26th, 2018 12:27 AM #7
The new Ecosport comes with a traditional 6-speed AT tranny, unlike the previous gen which had a DCT. This is the same 6AT tranny on the current Focus Ecoboost.
In 4 years of ownership of my Fiesta Ecoboost, I have had no issues with its 1.0L turbo engine even with my spirited way of driving, no overheats or turbo failure. It requires though low viscosity fully synthetic oil (5w20 or 5w30) and fuel must be 95RON at the mininum.
September 26th, 2018 12:31 AM #8
Anong engine ba ng Vitara nitutukoy u?
Under the skin, the Vitara gets a range of 1.0-liter and 1.4-liter turbocharged gas engines, which replace the existing 1.6-liter gas engine. In the United Kingdom, basic SZ4 and mid-range SZ-T variants will come as standard with the 1.0-liter engine, which produces 110 horsepower (82 kilowatts), while the top-spec SZ5 model will get the larger 1.4-liter unit with 140 hp (104 kW).
September 26th, 2018 12:34 AM #9
- Feb 2014
- 2,694
September 26th, 2018 12:34 AM #10yep the faulty DCT's are no more. but you still can't erase it from history. after having owned an eco for 1yr now it just feels like a low-quality car
Naglabas daw Ng delicà 4 x 4 Ang Mitsubishi ph Ng mid 2000s ? Is that true?
Mitsubishi Philippines
