Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
    #41
    When I let go of gas naffeel ko yung paghina ng engine.
    Quote Originally Posted by theblob View Post
    fuel injectors are off.
    #43
    Quote Originally Posted by diehard View Post
    The Honda 1.6 i-dtec has been around since 2013 and has proven reliable in Europe for both the CRV and Civic. More problematic has been the ZF 9-speed which has given headaches not only to Honda but also to Acura and FCA in various applications. There have been a deluge of customer complaints about lurching, rough shifting and even gear disengagement. Have diesel CRV owners in this forum noticed these problems that have plagued other ZF 9 speed equipped vehicles abroad?
    Probably none yet as these are still fairly new. The only minor lurching reported so far happens
    1. When you partially let go of the brakes from a full stop and ride them to creep.
    2. When coasting on level ground and it downshifts, the engine RPM rises by a few 100.
    Granted it's not as smooth as the Jatco made ones but so far, so good.
    Is this in D on level ground or going downhill sir?
    Aug 2008
    #44
    The downshifting while coasting and the subsequent rise in rpms seems to be a common complaint. Unfortunately, it looks like this is natural for this AT. Hopefully, the disengagement problem (which is potentially dangerous) has been resolved in the units sold in the PHL.
    Mar 2004
    #45
    Quote Originally Posted by claytonyu View Post
    Honda is not known for its diesels and therefore we wouldnt know yet whether or not their diesel is reliable. Also I am not sure if a 1.6 diesel is too small for the CRV, as I hear many people say its underpowered.
    Honda has been making diesel engines for decades in other countries ... as for the 1.6 liter engine ... it's a balance of fuel efficiency and power ...
    #46
    Level ground. As a driver parang feel ko nasusubsob ako paharap whenever I take my foot off pero hindi yata naffeel ng passengers yung makina kasi wala naman complaints so far.
    I used to drive an automatic Altis, when I let go of gas, it just coasts normally, pero ito feel mo talaga na parang humihina yung engine. As long as it won't create problems, sanayan nalang siguro.
    BTW nahirapan siya paakyat ng basement parking on D, dapat yata I shifted to S noh? Tapos lowest gear?
    Jan 2008
    #47
    Mas ramdam lang talaga sa diesel yung engine brake.. pag bitaw mo ng accelerator medyo may subsob ka agad mararamdaman.. sa gas halos wala yan unless high revving ka tapos biglang bitaw
    Paano mo nasabing nahirapan sa D? Hindi ba makaakyat kahit mag rev ka? Minsan need to rev higher than normal para maka bwelo yung torque converter
    #48
    Malamang siguro sa torque ng makina yan, which is typical of turbo crdis.
    Mar 2004
    #49
    If you are on sport mode, it will do that ... usually eco modes will let you coast ...
    #50
    Will try turning on Eco Mode.
    We had a 2010 Diesel Montero Sport which wasn't like that kaya naninibago ako.
    Thing is, hindi naman siya consistent. Minsan merong subsob minsan wala.
    On D, I almost had to floor it kasi kala ko titirik pero natagalan lang yata pag shift ng gear. On the next try I just did S tapos first gear, problem solved.
Cost of 5yr Ownership: CRV Diesel vs Gas
