Results 51 to 60 of 1594
May 20th, 2007 10:51 AM #51
I've been to some pretty steep inclines along the back roads of the Sierra Nevadas with slow vehicles in front of me. A/T doesn't seem to be a problem on the climb based on my experiences with the 95 Contour and 06 Sonata. Both cars never seemed to be shifting gears all the time. The biggest problem I had with mountain driving using an A/T is the downhill because of the rapid pick up in speed. Engine braking with a M/T car (my 91 Laser) or using the Shiftronic of the Sonata worked best for me.
I'll never take the 95 Contour up that route again. I still remember the burned odor of the brakes.
As for merging into the interstate, it's a matter of getting to the cruising speed of traffic. Any modern car with decent hp should have no problems doing that. I normally use the Sonata for interstate travel. Once I enter the freeway entrance, it's no problem hitting 75mph (the flow speed at our junction) before I merge into traffic. It's then just a matter of easing my way between cars. In fact, it's easier to merge with an A/T because my attention is focused on the cars I have to watch out for.
In CA, some cities make you stop (just before merging) which is downright silly. There, I would see the benefit of M/T. But, if you have a low hp car, it's still going to be tricky trying to merge on the freeway even if it has M/T.Last edited by Jun aka Pekto; May 20th, 2007 at 11:01 AM.
May 20th, 2007 12:56 PM #52
well the local mazda3 isn't a "decent hp car" -- but the "Sport AT" helps a lot for getting around those slow-moving buses.
going downhill, I've also noticed, the engine braking effect is MUCH less pronounced, even if the car is locked into a low gear. Damnable torque converter.
May 20th, 2007 03:55 PM #53
That's the problem... any modern car with "decent hp" tends to have much more engine than is practical in the Philippines.
Due to our traffic and tax situation, we usually get vehicles with the lower-output engines for the model range... which makes it difficult to overtake or merge onto the highway when they're equipped with ATs.
Of course, driving a car (our Crosswind) that gets to 100 km/h in 35 seconds (I've timed it), I'm one to talk...
May 20th, 2007 04:13 PM #54
Yeah, Jun said it rightly so - those metering stoplights just before the on-ramp are a PITA whenever there's NO traffic! Minsan nga eh yung iba nakabukas na lang pero it says "meter on" and the light is always green. Sheesh! Waste of taxpayers' money! Besides, it's also a waste of fuel to stop, and then accelerate to speed.
May 20th, 2007 04:52 PM #55
I 'kinda' like this though (in my experience, this happens only during morning rush hour traffic)- With a smile in my face,- I imagine myself as a Navy Pilot, being released from a catapult,- taking off from an Aircraft Carrier somewhere in the Pacific Ocean......
2701:bye:
May 20th, 2007 05:13 PM #56
Those metering stoplights sometimes tended to turn green right when a wall of traffic is bearing down at 80 mph. If you have a fast M/T car (like a Subbie), this is an excellent way to try your hand at 0-100 mph because that wall of traffic isn't slowing down for you especially when they can see it's clear ahead of you. If you're not moving fast enough, they'll get right on your bumper and honk their horn at you.
Yeah. I can see where M/T can come in really handy.
Tsikot Member Rank 4
- Jan 2007
- 2,326
May 21st, 2007 11:05 PM #57
May 22nd, 2007 12:10 AM #58
My preferences are normally for sporting cars (2-seaters, 2+2 sports coupes, and/or anything with a turbo) to have M/T. Shifting is part of the fun and I normally limit the occupants in the car to just me. Anything else can have an A/T so long as there's ample power in case I need it.
An A/T turbo Subbie..... That's hard to believe unless Subaru thinks most of its cars in RP will be stuck in traffic. Surely there are M/T Subbies over there.
- Jun 2005
- 866
May 22nd, 2007 07:58 PM #59Yun nga eh. Biggest problem d2 sa Pinas is because only a very few vehicles have CVTs as their auto gearboxes. Only like less than 5% of all vehicles in this country have CVT auto (Honda Fit/Jazz & City lang ata & Nissan Murano among others)....yet look at Japan tapos andami ng kotse na gamit ang CVT.
I guess na for the meantime, the presence of CVT cars in this country will be at the lowest minority. Sayang nga e.
May 23rd, 2007 09:52 AM #60
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
