Page 65 of 80 FirstFirst ... 155561626364656667686975 ... LastLast
Results 1,281 to 1,300 of 1594
    #1281
    M/T lost to A/T. Well at least in preference. No one prefer to drive a stick nowadays.
    A/T nowadays have evolved to the point that they are as good as M/T when it comes to drivability. Alagaan mo nga lang sa frequent ATF changes, tatagal na din.
    Quote Originally Posted by muypaquito View Post
    am really just dumb AF sa mga sasakyan.
    can anyone take a sample timeline/costs ng mga kelangang ialaga sa AT and MT? for sample the fluids, filters, oils... the frequency they need to be replaced with and cost.
    for AT,
    40,000km or 24mo generally for 4sp 6spd and including cvts. drop and fill prices vary because of the volume, 3-4iter 4-6liters 7-9 liters respectively.
    #1283
    For Subaru CVT trannies, it's 40k KM intervals for every CVTF replacement. Motor Image suggests to follow actual mileage rather than age. It needs around 13L for every CVTF replacement.
    Back with our old Accord 6th gen and City/Jazz 2009, it was 40k between ATF replacement. They require around 4L of ATF for every refill.
    pero mahirap talunin sa patibayan ang manual trans....
    kahit walang palitan ng gear oil eh hindi masisira......its virtually maintenance-free.....
    pero agree ako umaasenso na matic ngayon.... ang gaan idrive ng continous variable transmission...
    for the high torque diesels ie tbz colorado and rangers.. it actually doesnt last that long..
    Jan 2018
    #1286
    letsugas kasi sa mahal ng AT kumpara sa MT counterpart. hoping to get innova E. nakikipagtalo pako sa misis dahil ako itong mas consider ang AT para di mahirap sa trapik. sya naman gusto MT para sa extrang pera eh marami pa magagastos.
    #1287
    The MTF is not totally maintenance free. Pinapaltan din yan. Imagine that fluid just sits there without any filtration whatsover. Although the ATF goes through more pressure than the MTF.
    As per Tatsuru Ichisama of Spoon Sports he suggests that every change oil palitan din ang MTF. But for me its a bit overkill. Siguro after 2 or 3 change oil intervals tsaka isabay palit ng MTF.
    Dec 2009
    #1288
    Pinapalitan din ang manual transmission fluid, less frequent nga lang compared to automatic transmission fluid
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Apr 2008
    #1289
    Actually there are now so-called maintenance free automatic transmissions wherein fluid changes are not required and there is no transmission fluid dipstick. This is the type of transmission found in our 2011 Santa Fe 6AT. When the need does arise wherein a fluid change is required like being flooded or the like, fluid replacement is a huge pain in the butt.
    And then again, fluid changes only cost a few grand per change. For the manual, I've had to replace the Revo's entire clutch assembly after just 55tkms most likely due to being subjected to bumper to bumper city traffic for most of its life. Not to mention the trauma of failing to shift in the middle of the street when it finally gave out...
    Sent from my SM-G900I using Tapatalk
    Mar 2017
    #1291
    For AT, when stopping for long periods of time, do you:
    1 set to neutral and handbrake
    2 or leave it at D and handbrake
    Common answer from other folks is (1) but there's a youtube video from Engineering Explained saying that the shifting action from D-N causes wear on a more expensive part to fix than the wear when leaving it at D. (Well this is my understanding from the vid)
    Jan 2009
    #1292
    Quote Originally Posted by xnxnxn View Post
    Well, you have to define what "long" is. I do a little of both and the third option, which is to firmly step on the brakes while in D.
    Whichever option I choose depends on a number of factors. For short waits of less than a minute, I leave it in D with my foot on the brake pedal. If I need to remove my eyes from the road to fix/do something, I put it in N and apply the handbrake.
    There are situations when you will have to sacrifice a little wear and tear for the sake of safety. For example, it gets tiring to keep your foot on the brakes on long traffic stops of more than 90 seconds. If you just happen to lose awareness or become distracted, you might unintentionally release it and end up rear-ending somebody. Applying the hand brake while in D is also not a best practice as you might be tempted to step on the gas for any number of reason (ie. Increase the A/C cooling or you just want to rev up the engine). That could overpower your handbrake and also send you rear-ending the poor sap in front.
    The best option for long waits (90+ seconds, in my case) is to put in N and apply the handbrake. But even on shorter stops, if you need to reach for something behind you or under the seat with your eyes no longer on the road, just put it in N+handbrake and nothing you do short of accidentally pulling the shifter into D, would move the vehicle in any direction.
    Jan 2008
    #1293
    +1 on this.. kung crawling traffic brake lang.. pero kung full stop na usually may counter naman then lagay muna sa N.. mahirap kasi pag na lingat ka.. boom sapul mo agad sa harap mo.
    ngayon pag balik sa D wait a little say mga 1 sec. to fully engage the gear then accelerate normally. make sure na naka D ka na bago ka tumapak sa accelerator.
    Dec 2017
    #1294
    Quote Originally Posted by GTi View Post
    Perhaps this is the reason why I can't find the dipstick for the transmission. Now that you mentioned it, I'll check again my Owner's Manual.
    Mar 2018
    #1295
    I won't even contemplate of driving a M/T vehicle again.
    Using an A/T saves me a lot of physical energy. I hate that haggard feel when I still drove my previous M/T vehicle driving from QC to Taguig to Makati and last stop at Greenhills on a regular day. When we were invited to play badminton in Pasay, no choice ako but to take Greenhills and then EDSA. Upon reaching the court, ngalay na ang knees ko. Then after 2 hours of play, balik QC na naman via the same route. I need to ice my knees upon reaching the house hehehe.
    #1296
    Glad to see someone into badminton as well in the forum. Where do you usually play?
    Mar 2018
    #1297
    Good buddy, when we were based in Makati, we play in Powersmash, The Zone, Blu Rackets and BCMI. In QC, we play in Hemady, Centro, Dragon, and Power Up. In Pasay naman, sa 365.
    Now in Pampanga, sa Smash Power.
    #1298
    Oh you're not based in Manila pala.
    I usually play in Smashville but occasionally play in Centro, KPrime, and DASC as well. Would be nice to play with fellow Tsikot forumers someday.
    Mar 2018
    #1299
    Ah yes before I was joining a queuing group back in 2009 in Smashville. Good crowd and hard hitting players hehe.
    Nov 2011
    #1300
    Buti na lang nauso na auto brake hold. Now, I rarely shift to N even for 60+ secs. stoplights.
Battle of the Transmissions: M/T vs. A/T
