Page 58 of 80 FirstFirst ... 84854555657585960616268 ... LastLast
Results 1,141 to 1,160 of 1594
    Apr 2008
    #1141
    Considering the Tribute's weight penalty and slightly larger engine displacement, I suppose the FC is just about right. I shudder to think how much more the V6 variant consumes... It is usually driven for short distances only (3-6kms one way). I wonder how it would do in the highway. I've never tried it before. The diesels always get to run the long distance trips.
    Sent from my SM-G900I using Tapatalk
    Aug 2014
    #1142
    Hi po mga sir.. im planning to buy A/T cvt car. 7 speed daw po.. nagresearch po ako about CVT wala naman gears. Pano po nagkaroon ng 7 or 8th speed? Manual transmission po current vehicle gamit ko..
    Sent from my ZTE B2015 using Tapatalk
    #1143
    Quote Originally Posted by orbitz52 View Post
    the AT is programmed to set in at pre-programmed positions along the spindle, po. just to give the consumer a semblance of "speed".
    but you are correct. CVT is a practically stepless transmission.
    Aug 2014
    #1144
    Ano po nangyayari sir sa cvt kung isshift up ko paddle shifter? Or taas lang po rev ng engine? Okay naman po ba cvt? Minsan po mahilig ako magover take.^^
    #1145
    ^^^ We have traditional ATs, dual-clutch (DCT), and CVT cars at home. Wala naman ako problem sa overtaking. Yung Jazz 1.3L 5AT nga lang makupad so medyo kelangan timplado sa overtaking.
    Aug 2012
    #1146
    We have ASX 2.0 CVT. No problem on overtaking. Very responsive. Harurot agad.
    Sent from my D5833 using Tapatalk
    #1147
    What I noticed on CVT is that there is no sensation of gears shifting up and down. With my Forester, when I put the pedal down, the CUV shoots above triple digits and I notice that the dashboard displays that I am in 7th or 8th gear already (with no paddle shifting).
    Unlike with DCT, I can feel the gears shifting up from the low gears to the high gears. The 1st to 3rd is quite noticeable but the 4th to 6th gears is smooth and very quick.
    Aug 2016
    #1148
    Natuto ako sa manual mag drive pero stop na ako dring ng 3 years. Kung bibili ba ako automatic na car ay hindi ba ako mahihirapan mag drive or dapat manual bilhin ko?
    Feb 2014
    #1149
    how's the long-term durability of current-generation CVT's?
    Aug 2012
    #1150
    Quote Originally Posted by Sayu View Post
    Since marunong ka magdrive ng manual, mas madali lalo ang automatic. Wala pa ko nadinig na nahirapan sa automatic na galing sa manual.
    #1151
    learning to drive MT is like learning to ride a bicycle. you won't forget it, ever. but it may take a few practice laps to remove rust.
    at lahat nang kilala kong nag-umpisa sa automatic, ay hindi matuto-tuto sa manual pagkatapos.
    Jun 2015
    #1152
    No problem at all switching to automatic. Same case tayo. Ako naman 5 years nahinto sa pag-drive. Pagkakaiba lang naman nila ay gagalaw nang kusa ang automatic kapag wala ka sa neutral (o park).
    Expected ko nga dati para syang racing game na nakahinto lang hangga't hindi inaapakan ang accelerator.
    Tapatalked
    Aug 2016
    #1153
    For me it's manual. I've driven a range of M/T and A/T and it's true that you save more fuel using manual transmission. I've experimented on both transmission(Even the latest A/T models) and still M/T is still the winner in terms of fuel consumption(less consumed fuel). But with today's technology I think A/T is not far in gaining the advantage against the M/T. In terms of speed control, no doubt the M/T. That's just my 2 cents on this matter.
    May 2012
    #1154
    Both
    Da best i drive honda civic ek ko na manual lalo na kung galit na galit makina, dumadagundong
    Da best din matic naming mirage kapag drive drive lang pang relax...
    #1155
    I'd like the thought of getting a weekend or project car with an MT tranny. Maybe a WRX STi "Bugeye" or an Evo VIII/IX or E46 M3.
    Jul 2016
    #1156
    hello gud day,
    #1157
    I test-drove a friend's 2013 Accord Coupe V6 with a 6-speed MT last month. We drove at the twisties of the foothills. I didn't grind the gears or stall the clutch like when I was a beginner.
    I wasn't rusty at all. Before that, the last time I drove a MT car was an acquaintance's WRX back in 2007.
    The only strange thing I encountered was having six gears instead of five. That felt weird.
    #1158
    Since CVTs are basically friction driven, I'm concerned about its longevity. If only someone could invent a CVT with gear teeth.
    Aug 2016
    #1159
    Quote Originally Posted by vlake93 View Post
    e chief pag dating po kaya sa maintenance sa tingin ninyo po ok na din kumuha ng a/t ngayon? kasi diba dati way back 1990's pag naka a/t ka na sasakyan dapat mayaman ka talaga gawa ng daang libo ang pagawa neto pag nasira?
    Jul 2015
    #1160
    Quote Originally Posted by mckornick View Post
    Well, MT aint cheap also
Battle of the Transmissions: M/T vs. A/T
