Page 4 of 4 FirstFirst 1234
Results 61 to 72 of 72
    May 2005
    #61
    niky, what can you comment on the "scarpping issues" with the Navara? Nissan claims in its brochure that it has the highest ground clearance in its class, yet the 4x4ph website kept on bemoaning getting scrapes with each movement. I think bec. of its poor approach and departure angles, these are the areas that kept getting scraped and not the vital parts underneath (shaft, gas tank, etc..)????
    Jun 2009
    #62
    ,, the Navara has the highest ground clearance (on paper),
    it has also the longest wheelbase in its class,
    thus, its Ramp_Break-over_Angle is lower compared to its rivals.
    #63
    In TGP comparo, DMax won (over the Ranger and Navara 4x4s) due to its off-roading abilities and "efficient use" of what its has. Now, how will the DMax compare to the 2.5L Manual 4x4 Strada?
    Jun 2006
    #64
    Space is the final frontier in ute design, and which ute suits you best is a case of priorities. Should you take the large, carry-everything Nissan Navara ST-X, or save several thousand by buying the smaller but newer Mitsubishi Triton?
    - New Zealand Autocar "Space Truckin": Nissan Navara D40 (2.5L 172hp) vs Triton GLS Sport (3.2L 161hp ). Article in PDF format. Downloads in few secs.
    #65
    If you have the money to burn and issues surrounding practicality aren't a concern of yours... Go for the Nissan Navara 4x4! Impressive looks, power and speed! Stock set-up ka lang. Just replace the 'bading-sounding' horns to a decent one and you're ok to go!
    (I have NOT even had the chance to go 4x4 bro! Hehehe! But I enjoy the WOW factor and attention it gets from the public. Believe me, 'di na kailangan ng wang wang at blinkers. )
    Dec 2009
    #66
    kung s Lower Variant ka:
    mag Mitsubishi strada ka.
    Pero kung sa Hi End Variant ka:
    Go for Nissan Navara 4x4
    Pinaka malakas, pinaka mabilis na yan.
    Apr 2009
    #67
    di naman siguro every movement hehe. actually magkapareho lang ang hilux (which most say na super laki) and navara in terms of approach/break-over/departure angles given that the navara has marginally higher ground clearance (235mm right?). sa mga hilux 4x4 ng company namin (all stock except tires - 265/70 ata) may scraping din naman na nangyayari when we use it sa sie (mine site) though di naman ganun ka alarming. mababa lang tingnan sa picture (read: sa photos) ang navara but when you go out sa road, ang laki niya 'tol. bigla pumayat yung hilux, and when you see them both side by side, there is actually very little difference sa height (height ha, not ground clearance). i believe the navara is a bit lower to bring down the center of gravity for added "driftability" (according to niky of bigbigcar) or at least for more decent handling of corners sa city and winding roads sa countryside.
    so if youre driving 70 percent city and 30 percent rough/offroad, choose the navara na.
    pero kung gusto mo talaga offroad, navara pa rin hehe. pag serious offroading, better modify your suspension. stock cant survive serious offroading regardless of brand or make.
    palabas na raw sa 2011 yung facelifted navara, with a bit of increase in power and torque (190 hp from 174 hp and 450 from 403 Nm?) and lower compression ratio (16:1) and claimed lower Fuel consumption.
    and test drive first the navara, dont judge it by merely relying on reviews and photos. anyways yung mga nagreview din sa navara have tested it also.
    #68
    Low ground clearance is easily cured by getting higher profile tires. Thus also curing the "scraping". Test the more important features you most likely cannot change like handling, NVH, ride quality, brake assist, ABS, etc.
    Testing cars yourself and getting to know how its like to drive them is so much different than reading reviews. Take the test drive to where your next pickup will see most of its use. Try it out on trips you would normally take, with the people you would normally be with before you buy.
    Apr 2009
    #69
    agree on this! good point, dapat talaga i-test o i-consider yung mga features na you can't easily change
    malaki wheel well ng navara, can easily swallow 32 or 33" tires!
    you can easily modify the suspension. also, the navara has fatter CV (constant velocity) angles compared to other pickups in the segment so no need to worry about breaking those CV joints. sobra laki na ng navara pag lifted siya, sobrang angas din. hehe. (ive seen one on edsa and a handful sa subic)
    supremely planted pa rin sa ground ang navara kahit lifted due to its wider stance so no worries of losing its handling/cornering abilities.
    more HP to navara!
    Apr 2009
    #70
    Quote Originally Posted by Horsepower View Post
    big mutha truckers! - http://www.nissan.co.nz/data/press_a...ar%20Mar06.pdf
    Jan 2009
    #71
    [SIZE=3]As of March 02 2010, taken from respective manufacturer websites:[/SIZE][SIZE=4]
    <P1.0M
    HILUX 4x2 J 2.5 Dsl M/T 823,000.00
    [/SIZE]
    [SIZE=4]RANGER 4x2 XL PhP 845,000
    [/SIZE]
    [SIZE=4]D-MAX 4x2 LT MT 860,000.00[/SIZE][SIZE=4]
    STRADA 2.5 GL 4x2 M/T 860,000
    [/SIZE]
    [SIZE=4]HILUX 4x2 E 2.5 Dsl M/T 910,000.00[/SIZE]
    [SIZE=4]STRADA 2.5 GLX 4x2 M/T 925,000[/SIZE]
    [SIZE=4]D-MAX 4x2 LX MT 993,000.00[/SIZE]
    [SIZE=4]
    P1.0M+[/SIZE]
    [SIZE=4]RANGER 4x2 Trekker MT PhP 1,030,000[/SIZE]
    [SIZE=4]HILUX 4x2 G 2.5 Dsl M/T 1,075,000.00[/SIZE]
    [SIZE=4]RANGER 4x2 WildTrak MT PhP 1,080,000[/SIZE]
    [SIZE=4]RANGER 4x2 Trekker AT PhP 1,085,000[/SIZE]
    [SIZE=4]NAVARA 4x2 M/T 1,090,000[/SIZE]
    [SIZE=4]P1.1M+[/SIZE]
    [SIZE=4]D-MAX 4x2 LS MT 1,105,000.00[/SIZE]
    [SIZE=4]STRADA 2.5 GLS 4x4 M/T 1,128,000[/SIZE]
    [SIZE=4]RANGER 4x2 WildTrak AT PhP 1,135,000[/SIZE]
    [SIZE=4]NAVARA 4x2 A/T 1,141,000[/SIZE]
    [SIZE=4]D-MAX 4x2 LS AT 1,165,000.00[/SIZE]
    [SIZE=4]P1.2M+[/SIZE]
    [SIZE=4]STRADA 3.2 GLS Sport 4x4 M/T 1,265,000[/SIZE]
    [SIZE=4]P1.3M+[/SIZE]
    [SIZE=4]STRADA 3.2 GLS Sport 4x4 A/T (Standard) 1,305,000[/SIZE]
    [SIZE=4]D-MAX 4x4 LS MT 1,335,000.00[/SIZE]
    [SIZE=4]D-MAX 4x2 LS MT Boondock Edition II 1,345,000.00[/SIZE]
    [SIZE=4]RANGER 4x4 3.0L MT PhP 1,363,000[/SIZE]
    [SIZE=4]NAVARA 4x4 M/T 1,394,000[/SIZE]
    [SIZE=4]D-MAX 4x4 LS AT 1,395,000.00[/SIZE]
    [SIZE=4]D-MAX 4x4 LS AT L.E. 1,395,000.00[/SIZE]
    [SIZE=4]P1.4M+[/SIZE]
    [SIZE=4]HILUX 4x4 G 3.0 DSL M/T 1,408,000[/SIZE]
    [SIZE=4]RANGER 4x4 3.0L AT PhP 1,438,000[/SIZE]
    [SIZE=4]NAVARA 4x4 A/T 1,450,000[/SIZE]
    [SIZE=4]NAVARA 4x4 M/T KROME Edition 1,455,000[/SIZE]
    [SIZE=4]HILUX 4x4 G 3.0 Dsl A/T 1,464,000.00[/SIZE]
    [SIZE=4]P1.5M+[/SIZE]
    [SIZE=4]NAVARA 4x4 A/T KROME Edition 1,505,000[/SIZE][SIZE=4]
    [/SIZE]
    [SIZE=3][Not including the BT-50[SIZE=3]][/SIZE][/SIZE][SIZE=4]
    [/SIZE]
    Apr 2010
    #72
    Quote Originally Posted by ooba99 View Post
    That was an almost comprehensive post, sir number001. Europe NCAP crash test of the major pick-up trucks in a single post. Yung sa Hi-lux na lang, kumpleto na.
    if you'll visit the ANCAP site (aussie crash testing), hilux got 4 stars also. very similar to EuroNCAP results ang results nung ANCAP (they also say Triton/L200 has 4 stars, Navara 3 stars, Ranger 3 stars).
    here is the URL: http://www.ancap.com.au/results/168/
    there is also an evaluation or comments on what happened on cabin components (brake pedal movement after collision, steering wheel, clutch, dashboard - all stated with length of movement, like sa hilux, it moved daw about 40 to 60 mm rearwards and so on).
battle of the pick ups
