Originally Posted by
Wh1stl3r
Low ground clearance is easily cured by getting higher profile tires. Thus also curing the "scraping". Test the more important features you most likely cannot change like handling, NVH, ride quality, brake assist, ABS, etc.
Testing cars yourself and getting to know how its like to drive them is so much different than reading reviews. Take the test drive to where your next pickup will see most of its use. Try it out on trips you would normally take, with the people you would normally be with before you buy.
