Low ground clearance is easily cured by getting higher profile tires. Thus also curing the "scraping". Test the more important features you most likely cannot change like handling, NVH, ride quality, brake assist, ABS, etc.
Testing cars yourself and getting to know how its like to drive them is so much different than reading reviews. Take the test drive to where your next pickup will see most of its use. Try it out on trips you would normally take, with the people you would normally be with before you buy.
agree on this! good point, dapat talaga i-test o i-consider yung mga features na you can't easily change
malaki wheel well ng navara, can easily swallow 32 or 33" tires!
you can easily modify the suspension. also, the navara has fatter CV (constant velocity) angles compared to other pickups in the segment so no need to worry about breaking those CV joints. sobra laki na ng navara pag lifted siya, sobrang angas din. hehe. (ive seen one on edsa and a handful sa subic)
supremely planted pa rin sa ground ang navara kahit lifted due to its wider stance so no worries of losing its handling/cornering abilities.
more HP to navara!
