Page 145 of 154 FirstFirst ... 4595135141142143144145146147148149 ... LastLast
Results 2,881 to 2,900 of 3070
    Apr 2012
    #2881
    Quote Originally Posted by troytin20 View Post
    Hi guys hingi lang sana ako ng feedback/review sainyo regarding Morel Primo 10" and JL Audio W3V3
    I'm currently using a Hertz Energy 250.5 on a sealed box driven by Steg DST401D
    I want to know first if i would notice the difference if i change my subwoofer from my choices, thanks mga idol
    imo, if you intend to use the same sealed enclosure and you just change the sub baka minimal lang din ang difference. kung magpalit ka into a new enclosure designed specifically sa morel primo o jl w3v3 then malamang noticeable ang difference.
    Jun 2018
    #2882
    Hi. I would like to ask if there is a chance that a subwoofer and an amplifier can be installed on a stock HU on a 2017 Mazda 3 non-Bose unit? Thanks.
    Mar 2012
    #2883
    Sa tamang enclosure the JL 10w3v3 will out perform the primo. RMS pa lang and linear excursion makikita mo na mas lamang ang JL sa mga choice mo. But then car audio is subjective, there is no right or wrong choice of brand as long as it is installed properly. Sa iba, the Primo 10 might be good enough but sa iba naman mas prefer ang JL 10w3v3. Kailangan mo rin mag dagdag ng mono amp if you decide to go with the JL na choice mo.
    Quote Originally Posted by dongotskills View Post
    Any Stock HU ay pwedeng kabitan ng aftermarket subwoofer and amp. If walang low level out for the sub from your stock HU, bili ka lang ng LOC(line output converter) to send signal from stock HU to the amplifier though marami na mga bagong amplifier ngayun that accepts either high or low level inputs.
    Apr 2014
    #2884
    Had the same dilemma as you before
    Morel primo vs jl w3v3
    Asked some audio shops about the two, mas malambot daw laro ng bass ng JL, more SQ daw according to them
    Went with JL because I also heard it would be easier to sell 2nd hand in the future
    Aug 2004
    #2885
    Mickey posted one on their FB page. The amp was installed under one of the front seats. They also replaced the front seps and deadened the doors. I personally can't tell if they used a LOC or one of those new-fangled amps that D3nber mentioned but someone with more experience may be able to deduce from the pic of the cables going into the amp.
    Sep 2018
    #2886
    building an old school setup for a restored lancer boxtype and was looking for some suggestions from the experts
    have a few components already, so was hoping for some input on the missing ones
    Headunit: Pioneer KEH-P3700 (used) or Rockford Fosgate RFX-8030 (new old stock) - both cassette players
    The display works perfectly for the Pioneer, but no sound comes out when a test speaker was connected. Didn't get to play around with the settings yet when I tested, so it's possible it's still working. I preferred to use the Pioneer (to bring back memories of the KEH-P8250 I had before), but the RF head unit does have more features and looks even more old school
    Additional source: Sony Discman D-142CK Megabass (used) + original Sony Plate Arm/Gooseneck (new old stock)
    4-ch amp: Rockford Fosgate R400-4D
    Mono amp: Rockford Fosgate R500X1D
    Still missing:
    Rear: Deciding between 2 pairs of JBL GTO 939's or Infinity Kappa 693.11I, unless there are other suggestions for the same (or lower) price points? Would've wanted to find old JBL T545's or T595's, but looks tough to find (or too expensive)
    Front: Decided not to install fronts as I don't want to mess with the newly reupholstered sidings
    Sub: Was looking at either a single JL Audio 12W3v3-4 or Kicker Solobaric S12L7
    Expecting to have the doors and trunk lid treated as well (knowing the boxtype, will definitely vibrate)
    The car will only be used at most a few times a month, so really just a toy, but I do want that oomph. Appreciate any input, particularly on the rears and the sub.
    Thank you!
    Sep 2006
    #2887
    delayed response but puede naman. most sq way is to use a dsp to connect to the amp and control the settings...
    Sep 2006
    #2888
    feeling an attack of the upgrade virus...
    my current setup..
    Pioneer AVH8650
    Focal as65
    Focal p25 sub
    Focal FPP 4100 driving the seps
    Focal FPP 2100 driving the subs
    Audison Bit Ten
    Audiomax wires
    STP Aero Bomb deadening
    thinking of replacing my front seps and looking at getting a focal 165 f or 165fx.. appreciate advise if its worth upgrading.. or can you recommend alternatives for a max budget of 28k.
    malalang virus yan[emoji28]
    Apr 2012
    #2890
    Quote Originally Posted by mortis View Post
    my current setup..
    i think worth it sir. with your current hu, bit10 dsp and amps, swak yan to power yung 165f or 165fx. with your budget, add ka konti and pwede rin yung older K2 power series es165k. you get better sq and headroom.
    Sep 2006
    #2891
    ramdam ba ang difference between the 165f and 165fx.. sulit ba hung 6k difference?
    Apr 2012
    #2892
    i have the 165f so far ok naman. di ko pa napakinggan yung 165fx, magkaiba lang yata yung material ng speakers. you can't go wrong with any of them, but if nagtitipid ka, go with 165f then yung difference i-allot mo na lang perhaps sa cables, deadening, tuning/installation.
    Sep 2006
    #2893
    tnx..
    Apr 2012
    #2894
    tnx..
    may current set up ka na nga pala so yung FS na lang palitan then re-tuning. better siguro go for the higher 165fx na lang para di ka na mag-isip later what if kung yun ang upgrade ko lols!
    Mar 2018
    #2895
    Hello good day mga sirs. Hingi lang po sana ako ng recommended na application for android based head unit para po sana ma fine tune un sounds ng sasakyan po. Thanks in advance po.
    Oct 2007
    #2896
    Good evening mga sir, I recently upgraded the stock speaker of my Mazda 3 to focal 165AS front and 165SC rear, tanong ko lang, na notice ko lang kasi minsan yung sound humihina and then lalakas, ano kaya ang problema??? I plan to go back to where I have it installed but I want to hear from you guys muna baka alam nyo, thanks!!!
    #2897
    Only at louder volumes? Baka stock head unit can't output enough power.
    #2898
    bago magpalit, ganyan na ba?
    o, nag-umpisa lang pagkatapos mapalitan?
    kung pagkatapos, my simplistic mind would suspect loose connection.
    Oct 2007
    #2899
    Quote Originally Posted by mda View Post
    Yes sir, only on louder volume.
    No sir, before on stock di naman ganito, it just started when I replaced the stock speaker.
    #2900
    Yes sir, only on louder volume. No sir, before on stock di naman ganito, it just started when I replaced the stock speaker.
    You need an amp pag ganun but you'll need to confirm.
audio set-up for beginners [continued]
