Page 95 of 154 FirstFirst ... 4585919293949596979899105145 ... LastLast
Results 1,881 to 1,900 of 3070
    Feb 2011
    #1881
    ^ will depend on your goal sir. Mine was SQ when I spent 20k on my Swift. Here is the breakdown.
    Flux FS260 Seps - 12000
    Custom Sailpods - 3.5k
    Spacer - 800
    STP Deadening - 4.5k
    Very pleased with the result. Bang for the buck itong Flux seps.
    May 2010
    #1882
    Saan mo sir pinagawa? Thanks.
    Sent from my MI 3W using Tapatalk
    Feb 2016
    #1883
    Quote Originally Posted by sientobente View Post
    Halos same price lang dito Sir. Sa tingin ko mapapagastos ka din sa dashkit, dito around 3k din yun. Hintayin na natin yung 8850BT, kasi kahit ako yun din inaabangan ko for my crv. Baka raw June lumabas.
    Hmmm cge iintayin ko nalang muna. Medyo may ibang paglalaanan ng budget sa ngayon hehe. Tapos siguro magmumura 8750bt kapag lumabasang 8850 hehe.
    Sent from my C6903 using Tapatalk
    Feb 2011
    #1884
    Quote Originally Posted by romeocharlie View Post
    Kay Jonz/Simplesound sir.
    Mar 2005
    #1885
    Spacer - 800
    No amp used sir? Aftermarket HU ang gamit?
    Feb 2011
    #1886
    Quote Originally Posted by jmpet626 View Post
    No amp sir. Although the specs is not listed, the sensitivity of Flux is pretty good to be powered by the HU.
    Oct 2008
    #1887
    Spacer - 800
    Sir sientobente, san nyo po ito pinagawa?
    Feb 2011
    #1888
    Quote Originally Posted by al shaheen View Post
    Kay Simplesound sir. Siya rin gumawa dun sa CRV ko.
    Oct 2008
    #1889
    [QUOTE=sientobente;2715425]Kay Simplesound sir. Siya rin gumawa dun sa CRV ko.
    Ah, ok salamat
    Oct 2008
    #1890
    do you guys know a reputable shop who carries pioneer HU, back up camera and back up sensors, and are open on sundays? Thanks...
    Mar 2005
    #1891
    Quote Originally Posted by 5000rpm View Post
    Sa Cartronics along Del Monte bukas sila ng Sunday.
    #1892
    kapag may subwoofer ba pwede 1 to sawa magpatugtog or kailangan mo din imonitor kung ilang minutes/oras mo na sya nagagamit ..... salamat
    Aug 2012
    #1893
    Quote Originally Posted by aprilboyidol View Post
    If you need to monitor your use, then something is wrong with your setup. Decent equipment should be able to use kahit 24/7 pa.
    Sent from my D5833 using Tapatalk
    Aug 2010
    #1894
    Your diagram will be: Subwoofer - Amplifier - Source - Power.
    Pwede ba "until sawa" ang playing time? This will depend on your power source.
    - With the engine on, your amplifier gets its power from the alternator given that your alternator can handle the amperage/power consumption of your sub. How long can you play will depend on how much gas is in your gas tank.
    - With the engine off, your amplifier gets its power from your battery and how long can you play will depend on the amount of power stored in your battery.
    Hehehe, personally, I can only play my system at a concert-level-loud-inside for around 3 hours lang. Reason for this is that my subwoofer's amplifier will go into thermal protection afterwards because it's too hot and I'm hitting 90 Celsius inside it (and around 65Cs on the processor nearby).
    There's only so much you can cool down when you have 2kW of Class A/B power on-tap for your subwoofer so far this only happened 2-3 times a year lang naman (usually if heavy traffic/deadlock). Most people don't really worry about their heat generation though since most subwoofer amps nowadays are efficient using Class D topology designs.
    Oct 2008
    #1895
    thank you sir
    Apr 2016
    #1896
    Guys gusto ko simple audio setup sa 1996 pajero intercooler. I have 2x teac 6x9 320w, 2x teac 6.5 2way. Problem ko is saan maganda ilagay ang power amplifier. hindi pwde kasi sa ilalam ng driver and passenger seat kasi meron aircon vents and meron kasi shock absorbers both seats. hindi din pwde sa ilalim ng 2nd row at masikip dun tska may tatamaan na bakal. Can anyone suggest a good location ng stereo amplifier sa pajero intercooler? Thanks
    #1897
    mga sir ano po ba mas OK for SQ component front + coaxial rear or component front tapos subwoofer kailangan ba sealed kasi ayoko nung bumabayo tamang bass lang ..... salamat
    Dec 2007
    #1898
    Components front plus subwoofer on a sealed enclosure kung ayaw mo nang bumabayo. With regards doon sa amplifier mo, pwede mo ikabit sa enclosure nang subs.
    #1899
    depende sir. sedan or van? meron na po ba speakers sa rear kahit stock? kung wala, is it ok for you or the passengers na walang speakers sa rear?
    #1900
    Quote Originally Posted by jhnkvn View Post
    thank you po
    Quote Originally Posted by markygy View Post
    thank you po
audio set-up for beginners [continued]
