Results 901 to 910 of 3070
December 28th, 2013 05:43 PM #901
Butyl is rubber. Asphalt.. is well.. asphalt.
How to tell them apart? Hard to do. I mean you don't want to light your doors up right?
Best bet is to simply start by purchasing stuff that you're sure is made of butyl.
Based on your posts dito sa tsikot and sa KAC. Di ko talaga alam if your installer is recommending you for a second layer (Tsikot) or not (85% na daw yun one layer -- KAC).
- Apr 2008
- 27
January 13th, 2014 05:52 PM #902Sir jhnkvn,
I have a question regarding power handling ng head unit, I recently had a Pioneer DEH-X2650U installed on my Suzuki Swift, I want to change both front and rear speakers, for now im not planning to get an amp. When i do choose a speaker will speakers with 2ohms work well with the head unit? or should i use 4-8ohms? I plan sana to get a JBL GTO608c for front and a JBL coaxial sa likod.
Thanks
January 14th, 2014 12:37 AM #903
Try to get the 4ohms as much as possible. As every electrical engineer knows, ohms is a measure of resistance -- in this case, the flow of electricity. The lower it is, the less resistance there is. Problem is, most head units aren't stable at 2 ohms. However, there's no problem in using 4 ohms and 8 ohm drivers.
The good thing here is that most car audio drivers are 4 ohms and home audio, 8 ohms. Where the hell did you get the 2 ohm driver? :O
- Apr 2008
- 27
January 14th, 2014 12:55 PM #904
January 15th, 2014 11:17 AM #905
January 15th, 2014 11:00 PM #906
may shop/s ba kayo na mare recommend that
are good in installing deadeners? balak ko magpalagay this weekend
sa front doors ng revo ko muna at kung effective siya eh baka lahat
ng door panels eh palagyan ko na....nagbabasa basa pa ako sa
sound setup kaya sound deadening muna uunahin ko hehe....salamat!
January 16th, 2014 12:41 PM #907
January 16th, 2014 01:00 PM #908
Bili ka na lang heatgun and deadening materials tapos DIY like me. Mas maganda pag ganun kasi ikaw didiskarte kung saan panel pa ng auto ang kailangan dagdagan kesa naman pabalik balik ka sa shop tapos doble doble gastos. Yung sa akin binili ko lang dati yung deadening for 150 petot yata per meter kumpara sa mga shop na more than 1k minsan. Sarap pa ng pakiramdam pag natapos mo na yung project dahil atat ka na subukan kung ano ang improvement sa sounds mo.
Sent from my iPad using Tsikot Forums
January 16th, 2014 09:11 PM #909
thanks jhnkvn & wezz.
unfortunately i think im not yet prepared to tinker with a car so
i've asked a quotation from mickys autosound and it's 4.5k for
the front doors only....a bit expensive???
January 16th, 2014 09:52 PM #910
Wow. No brainer to get the totl turbo over the seltos sx 1.4 turbo that also costs around 300k plus...
2022 Hyundai Creta
