ummmmm... gusto ko po yung malinaw lng yung tunog na pag nilakasan ko ay hindi sabog yung sound.. shmpre gusto ko rin lakas din konti yung subs..
wala po ako idea kng anong seps, amp and subs..?
cguro mga 10-15 swak na kaya yun?
salamat..
salamat..
meron pa po akong isang idea.. paano po kung pinalitan ko yung front and rear speakers lng tapos lagyan ng amp. ok na po ba yon? o bitin pa ren at ano? salamat po..
ssaloon: sir, stock lahat ng speakers, JVC 40w x 4 HU and cd changer. mga 15k budget ko.
they say targa speaker e tipid meals pero maganda tunog, what would you recommend sir?
swak yung budget mo for targa seps, fenton FA41000 amp and a targa 12 incher with sealed enclosure. maybe the other peeps can recommend a setup to fit your budget.
OT: making this thread sticky to benefit the rest of the forumers.
jbl gto. medyo mura... nasa 4-4.5k siguro. pero beware dahil sa pagkakaalam ko, may lumabas ng peke nito. tapos fenton na 4ch ok na un. un ang gagawin ko sa rav4 ko e. saka na muna sub... more on clarity muna ko, lowbudget lang kasi ako e
if you are really on a tight budget is suggest that you get a nice 4 channel amp with front and rear crossovers that is bridgeable (pwede gawing 2 channel lang)
then what you do is use the stock front speakers of your car, driving it off the front channels of your amp, crossed over at around 80 hz. then you bridge the rear channels and drive a single 10 inch sub using the bridged rear channels, crossed at 80hz and below.
most of the newer cars have fairly okay speakers, its just that they can't handle the low bass at loud volumes. if you let them play 80 hz and above, they will be fine, kahit laksan mo pa.
andy
mga sir,,
kung walang problema sa budget, walang paguusapan sa pera. anong set up sa sounds ng kotse nyo ang gusto nyo.. san sa tingin nyo pinakamaganda mag pa setup ng ganito? yun pong di taga at parehas lang... pwede po bang makahingi ng list ng items na bibilhin o ikakabit..
Thanks,
zric
sa mickey's autosound ka or dbaudio if money is no object. then go all out focal! :DOriginally posted by eric_zilt
mga sir,,
Thanks,
zric
if you say na cost is not a consideration, then you will get a million different answers because cost is the biggest factor to consider when designing a system.
the advice that i can give is if cost is not really that big a deal, try to go with a 4 way setup. this is usually comprised of a pair of tweets, a pair of midranges, a pair of midbasses, and a single or pair of subwoofers. pwedeng full active or passive and active combined. a 4 way system with a good eq and crossover will be nice
andy
I just bought a UP6 (di pa installed) I am looking for budget amp to power it and an installer that had previously installed speakers for RAV4 2004 model. Ayaw ko yung manghuhula kung paano tangalin ang door panels.
Tulong mga kaibigan. salamat
tama ka dyan pare, go to an installer na maraming experience na kasi bad trip sung sigeng hila sa panels mo. pagkatapos ng install, dami ng squeaks and nakalawit na dahil sa sobrang pwersa.
andy
mach2audio sa pasig area. pwede rin sa mickey's autosound (same vicinity)
diba imomold pa ung bagong spealer with mdf pag magpapalit ka ng seps? nakita ko lang sa pics ni cardo. sa audiologic yata siya nagpakabit e
Di ko na talaga kaya ang sounds ng ride ko. After thinking things over, I've decided to do step 2 first. Pero parang nabaliw ako at the thought na my budget for "decent" speakers should be in the 12k-17k range. Ganito ba talaga yun? I was thinking of spending in the 5k range lang, or sayang lang ba yung upgrade na gagawin ko. Or baka di considered na upgrade ang gagawin ko? Hahahaha!Step2. is to buy a good front speakers (2way seps preferrably 3way) not lower than 9k- 35k should at least 75-125w power handling depende sa level hanap mo. Recomended for a decent seps around 12k-17k(2way).
I have some experience in setting up my own Home Theater System (I ended up with 2 fronts and 1 center speaker with a receiver) kaya I know that one should spend kung gusto mo ng quality. And there are upgrades which aren't really, and will just make you upgrade again, leading to even higher cost.
Can you recommend:
(a) car audio shops na mabait ang owner who can take a look at my current set up and tell me what i should do first? i.e. tama ba na step 2, or puwedeng step 3 and 4 na lang, or dapat ba step 1 talaga;
(b) speakers in the 5k range? kung meron man? Hahahaha.
(c) websites that i should go to, so i can read up on what's a good set-up.
I'm after SQ btw.
april ryan,
imo, mb quart, dls, jl ok sa SQ.
pero antay lang ako ng naka jbl GTO den audition ko, pag nagandahan ako sa tunog, un na lang bibilin ko. nasa 4-4.5k range lang siya...
try visiting www.kotseaudioclub.com
may mga tsikoteers din dun.
Madugo talaga kung after ka ng SQ. IMHO, follow mo yung isang post dito (forgot ko kung anong thread; kay maestro yata) na slowly nya develop yung set-up nya. Quality is expensive.HTH.Originally posted by April_Ryan
I'm after SQ btw.
