Originally posted by ssaloon Mach2audio 09178476259 (Pasig)
Dbaudio 09178126620 (Mandaluyong)
Intenz 09166464030/ 02-7316479 (Banawe)
Mickey's Autosound 09175299309 (Pasig)
i've been to Intenz in Banawe, but have no idea where the others are located. Makikita ko ba sa mga recommended shops, or can someone post directions and landmarks? Thanks.
in my experience, as long as you get a decent pair of separates and don't feed it more power than what it can take, then it will sound better than stock. especially in the future when you add a high pass crossover, then you crank up the volume.
personally, if you don't have the cash and you don't intend to compete, don't buy the P12,000 and above separates, sayang lang.
you can get good separates from 5 to 8 thousand and it will be much better than stock. just remember that your stock speakers probably cost P1500 pesos lang maximum na yun.
SQ is very subjective kasi. my benchmark is clarity and lack of distortion. that is why my priorities are a decent set of separates. a sub and amps that can drive them with built in crossovers. for me, that is enough na, if you do not intend to compete or if you don't want to show off in the parking lot
Originally posted by luckytruck personally, if you don't have the cash and you don't intend to compete, don't buy the P12,000 and above separates, sayang lang.
.... for me, that is enough na, if you do not intend to compete or if you don't want to show off in the parking lot
andy,
thanks. i definitely do NOT want to show off in the parking lot. i don't even like cranking the volume in my stereo. hahahaha!
i just want the stereo system in my car to sound good. na-spoil na yata ako with my simple HT set up at home. and i think it would be unacceptable to spend more on my car speakers than on the speakers in my HT set up. so OK na siguro yung mga 5k-8k range.
i went to Autosport in megamall yesterday, and their JBL GTO series starts at P4,120.00. Maghahanap na lang ako ng other brands in the same price range.
Originally posted by luckytruck targa 2 way separates and targa sub and a 4 channel amp. di aabot ng 15,000 yan, including install.
andy
called up one of the recommended shops, talked to its owner. for all-targa budget set up, P15k ang quote sa akin. he was really nice though, and took time to explain things to me.
ok lang ba na seps lang muna dagdag ko? i'm leaning towards JBL GTO (4k) or DLS (nasa 6.5k range). i wish i could afford the seps and amp thing, pero nasa 10-15k na yun. di kaya. i don't think i even want a sub, depende siguro how the whole thing sounds.
oo naman. pwede naman paisa-isa lang muna upgrade kapag di pa kaya ng budget ng isang bagsakan. give yourself the luxury of time to really find what parts you want ;)
go ahead and buy the separates first. then if you are not satisfied, get the 4 channel amp and sub. sa four channel amp and sub, you might want to buy second hand. maraming nag-uupgrade dyan. pero sa separates, better kung brand new (opinion ko lan gito)
Dito na lang po ako magtanong, ayaw ko na start ng new thread...
Is it advisable to buy an amp in the US for use here? Ang apprehension ko lang naman ay warranty pag may problema. Kasi yung mga narito parang last year's model pa tapos mahal. Or may iba pa bang dapat i-consider?
What do you think of Comp VR 10 and an RF amp, maybe P3002, bridged 300Wx1? Dagdagan ko lang muna bass ang stock setup ko.
ok naman! warranty lang talaga ang magiging problema mo in the event something goes wrong. another would be the shipping of the unit, and the damage that might be sustained kung bara-bara yung courier.
Thanks ssaloon. I might be going there (padala ng opis) this year. Kaya walang problema sa shipping. Hand carry ko. Hehe.
Meron na bang naka-experience na nasira yung bili sa abroad? Meron akong nabili na digital cam sa HK ok naman hanggang ngayon, 1 yr na. Pero syempre na test ko habang andun ako.
Puwede bang ipa-test yon? Pero amp, pano mo masisiguro na ok?
tanong lang po... ano po ba ang size ng front speakers ng cr-v 2003? kse po, pina-set-up ko na ung sounds nung kotse ko... comments and suggestions needed..
2 amps (JL Audio ung isa)
2 kicker solobarric.. old model
2 crossover
1 pair ng tweeters
medyo butas na po bulsa ko sa set-up eh, ano po mare-recommend nyo na pwede kong ipalit dun sa stock na front speakers? thanks po...
2 crossover
1 pair ng tweeters
