so i have a car with stock everything...which area should i start my modification? speakers?
quoted from autoindustriya.com
Suggestion on Car Audio setup for Newbis
« on: May 29, 2003, 10:50:02 pm » Reply with quote
If you have cash on hand the sequence of your buying should be
Recomendation for buliding a good quality setup slowly and not to keep changing them in the future for a better one as you accumulate your budget as months go by..
step 1. headunit not lower than 10k-35k depend sa level ng quality habol mo recomended decent headunit 13k-20k
(Brand- Pioneer/ Alpine/ Panasonic/ JVC /Sony)
And if you have sufficient money left.......
Step2. is to buy a good front speakers (2way seps preferrably 3way) not lower than 9k- 35k should at least 75-125w power handling depende sa level hanap mo. Recomended for a decent seps around 12k-17k(2way).
(Brand- Boston/ Infinity/ Focal/ Dyne Audio/ MB Quart/ JBL/ JL Audio/ DLS/ Diamond Audio)
After a few months if you have more money........
Step3. Buy a good amp 1pc 4ch. around 10k to 30k around at least 75w- 150w per channel recomended front power 100-120w class A/B Recomended price for a decent amp would be 16k-22k at least (60w x 4ch).
(Brand- Kicker/ Rockford/ JL Audio/ DLS/ PPI / Audison/ X-tant)
Step4. Buy a good sub 1pc to 2pc Total budget around 5k-25k 1pc or 2oc depend on price. power handling around 100-400w per pc. Recomended budget for sub 100-150w per pc. Recomended price for decent sub would be 8k to 15k at 250w per pc.
(Brand- Kicker/ Boston/ Rockford/ JL Audio/ JBL Soundstream)
Step5. Buy a 2nd amp for your sub if needed and use your existing amp to power your front and rear or front only at higher wattage (80w-125w seps). Budget for sub amp 16-35k 250w to 500w per channel or mono channel. Recomended good quality sub amp price 23k-30k preferrably same brand as your existing amp. recomended decent power at 500w mono if you decide for buy a 2nd sub or 300 w if using only the existing sub.
Step6. Buy a good sound processor or EQ at least 20 band or 10 band parametric best is 30band . Price range recomended around 10-16k.
(brand- Audio Control / Rockford/ PPI/ Autotek)
When all else fails, follow instructions.
sir toolightz
thank you po sa reply. saan po nilagay ng friend ninyo yung box para sa subwoofer. dont want the box to be visible..
thak you sir toolihtz for the reply, iyung dimension ng box ko sir is nasa h=16, w=34, d=8 lang po yata ported with 4inches pvc 12" long port. siguropo talagang medyo maliit enclosure kaya siguro medyo bitin sa bass. ano po kaya ma irecommend ninyo na size ng box. iyung po palan p3 sub ko is iyung shallow series na 4ohm dvc. salamat po ulit.
sir patulung po,gusto kung lagyan ng sound yung honda city ko,gusto ko 1sub,1pair sep and ampli,type of music ko po rock,heavy metal,anung brand po ang maganda?budget 50 to 60k?tig ilan watts po ang gagamitin bawat isa?sir may nagsasabi maganda daw po yung HERTZ?sana matulungan nyo po ako maraming salamat po..GOD BLESS![]()
sir good day, nabasa ko ang pinost mo tungkol sa sound set up, andito ako ngayon sa america nagbabakasyon, at bumubuo ako ng sound set up para sa kotse ko, naka bili nako ng sony explod 6x9 4way 330watts, xplod 10" subs 1100watts, xplod 4 channel amp 600watts, xplod seps 260watts at jensen vm8013 head unit at 5000k scoche capacitor. ngayon alam ko na marunong kayo pag dating sa sound set up, ano ang pwede ko pa idagdag sa set up ko, kelangan ko pa ba dagdagan ang amp ko? ano sa palagay mo ang sony explod na set up? sale kasi ang sony dito at magpapalit na sila ng mga modelo, nabili ko lahat sila mahigit 450 dollars.pinag iisipan ko din kung dagdagan ng 1 din pioneer sound processor medyo mahal nakasi 200 dollars more tanong ko lang kung ok na ba ito?at kung sino ang pwede mag install nito sa banawe first time ko mag set up ng sounds sa car ko. maraming salamat
Okay naman sony xplod. Depende na iyan sa mag set up ng sound system at magtotono para maging maganda tunog.
ssaloon,
Suggestion for newbies ba yan? Eh hindi presyong newbie yan, ha. hehehehe.
Ano na lang ang system ko kumpara diyan sa mega-buck 'newbie' system nila? hehehehehe.
I'm a beginner:
*I used my stock head unit (Pioneer). Added a 12 disc CD changer I salvaged from my old Benz.
*Targa TX-series 2 way seps + Targa 10" SVC Subwoofer.
*Had GlennSter build me a box out of MDF.
*Bought KCboy's Alpine Amp for a really great price.
*Used wiring salvaged from our old Galant SS.
Ayos na ayos.Sa bagay, hindi naman ako masyadong finicky with these kinds of stuff.
kingmarc::: Could you be more kind enough to elaborate more on all of your queries?
Please indicate what vehicle, sound setup, budget you will work on.
