Page 340 of 392 FirstFirst ... 240290330336337338339340341342343344350390 ... LastLast
Results 6,781 to 6,800 of 7833
    Mar 2017
    #6781
    Quote Originally Posted by zechs View Post
    Just finished detaiing the daily driver. 4 days din inabot. I was not rushing this hahaha
    Was able to try megs fast finish last night and it was by far the easiest sealant to apply. I mean easiest is an understatement. You apply it using a microfiber foam applicator. Much easier to control. I made 2 coats of it. First coat last night then let it cured for 12 hours and the applied another coat. Hopefully it is durable.
    I noticed a reduction in dust sticking to my car after using FF. Lasted around 3-4 months (1 coat).
    Quote Originally Posted by AllenR View Post
    Anti static yan talaga kailangan!
    Feb 2010
    #6783
    Paps, how much yung megs ff? If it lasted for 3 to 4 months then that must be good product.
    Mar 2017
    #6784
    True! For my purposes, the product is well worth the price even if it's only for that property. Dusty dito sa amin
    Mar 2017
    #6785
    Quote Originally Posted by polar01 View Post
    Around P1,000 (converted) ata IIRC, sa Amazon ko kasi binili. Not sure if meron sa mga local stores.
    Feb 2010
    #6786
    Great! Will check. Thanks.
    Nov 2017
    #6787
    Eto ba yun?
    Meguiar's G1839 Ultimate Fast Finish - 8.5 oz | Lazada PH
    Mar 2017
    #6788
    Yup! Iyan yun. Nabili ko ng $20 sa Amazon, sinabay ko lang sa balikbayan box.
    Ah UFF 🤩
    May 2017
    #6790
    How does Meg’s FF compare with ULW or Collinite 845?
    Oct 2003
    #6791
    What do you mean? To apply? Easiest. Almost little to no buffing required. Durability? I have yet to see pa.
    Apr 2012
    #6792
    ^ test mo din hydrophobicity
    Oct 2003
    #6793
    I'm going to delay the first wash para ma totally cure ung sealant. Haha hopefully it doesnt rain.
    Aerosol pala UFF [emoji58]
    Oct 2003
    #6795
    Yes aerosol like Sonax Polymer Net Shield. Mas mahirap lang ung availability ng Sonax products dito sa atin.
    I made 2 coats of UFF on my daily driver and barely used any product. If the durability holds (or even it doesnt) value for money itong UFF since you can just reapply it again and again.
    Oct 2003
    #6796
    Kinda dusty
    Apr 2012
    #6797
    Kinda dusty
    dust magnet? [emoji848]
    Oct 2003
    #6798
    Either that or sobrang dusty talaga sa amin. If only pwede touchless wash...
    Apr 2012
    #6799
    rinse and pat dry. if dusty sa lugar niyo, get the softest car cover you can buy and cover your car. just be extra careful while covering and uncovering because even car covers can induce light scratches...tamang OC 🤩
    Nov 2014
    #6800
    sa polishing, pinaka-makintab na nagawa ko sa pyrenese black ay yung nakikita yung parang blue flakes sa reflection ng paint kapag naarawan. sa m205 ko napakintab ng ganun...
    i have not try meg's fast finish. the only meg's product i have is ultimate black plastic restorer. so far effective naman, you just need to apply liberally sa mga namumuting plastic trims, let it linger then wipe off. dati pahid-pahid lang ginagawa ko, its not going to work. you need to parang soak the part like mga front o rear plastic bumpers na namumuti para ma-penetrate ng restorer. i use small paint brush to apply.
    Thanks for these tips sa plastic restorer! I just bought that also, will use a paintbrush na rin and apply liberally
    Parati kasing bilad kotse ko so pati yung base nung rear wiper ko namumuti.
"Tamang OC lang" - a newbie's guide to car appearance maintenance
